hubcenteric ring size driving me crazy! help needed. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-12-2007, 03:35 PM   #1 (permalink)
View clarkgrizwald's Photo Gallery
i went to 3 different places today. just to see if i could find out the right size or buy some hubcentric rings. none helped me. im pretty positive my camry wheel bore had a diameter of 60.1mm. and im putting on some mazda cx7 wheels. the problem is finding what diameter these wheels have. am i seriously going to have to buy a caliper just to figure out what size i need??? im getting a little frustrated. anyone have advice?
clarkgrizwald is offline   Reply With Quote
Old 12-12-2007, 04:35 PM   #2 (permalink)
Here and there...
Gameroom cash: $153229
iTrader Score: 6 reviews
View lammydi's Photo Gallery
Hi Clark,
You are correct that our Camry centerbore is 60.1mm.
In search around on Mazda forum, I found the following info:
http://www.imazda.com/forums/showthread.php?p=133839
Hub Diameters
All 4-lug Proteges: 54.1mm
All 5-lug Proteges: 67.1mm
3: 67.1mm
626: 67.1mm
6: 67.1mm
So I can only guess that the CX-7 also have 67.1mm.
So I called the 1010tires.com only to find out you have a problem.
The Hub Centric Rings (HCR) will not work in your case!!!
Here is why, the HCR is designed to work with aftermarket wheels only.
Because all manufactor wheels were designed to fit exactly onto their own inner diameter (Toyota Camry=60.1mm, Mazda CX-7=67.1mm) so when aftermarket wheels were designed they made the wheel center bore (called outer diameter) big enough to fit mutiple cars. Well, that give us the "room" to have the Hub Centric Rings sit inside.
But the CX-7 wheels were designed to fit all cars that have 67.1mm. So the "hole" of the CX-7 wheels don't have anything for the HCR to fit snuggly inside.
Sorry, in your case the HCR will not work for you.
Old 12-12-2007, 04:48 PM   #3 (permalink)
'07 XLE
Gameroom cash: $283530
View njerald's Photo Gallery
Gen6
Just have them made special for you:
http://www.prestigewheel.com/mainHubRing.htm
Old 12-12-2007, 04:49 PM   #4 (permalink)
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&viewitem=&ru=http%3A%2F%2Fs earch.ebay.com%3A80%2Fsearch%2Fsearch.dll%3Ffrom%3 DR40%26_trksid%3Dm37%26satitle%3D180192968575%26ca tegory0%3D%26fvi%3D1&item=180192968575
lammy is this not the exact sizes you were talking about? why wouldnt these work?
Old 12-12-2007, 04:59 PM   #5 (permalink)
'07 XLE
Gen6
The OD is too small.
Close but not tight!
Old 12-12-2007, 05:27 PM   #6 (permalink)
the outer diameter is 67.1 on those rings, what should it be?
Old 12-12-2007, 05:35 PM   #7 (permalink)
'07 XLE
Gen6
It says 67.1 in one place and 67 in 3 places. Typical EBAY description!
If it really is 67.1, it is perfect.
Old 12-12-2007, 05:43 PM   #8 (permalink)
Here and there...
It's kinda hard to explain it. It took me a while on the phone for the guy to explained to me.
If you look at aftermarket wheels, the outer diameter hole has a little deep plate to hold the Hub Centric rings. They designed it like that to hold those rings.
The stock rims don't have those "deep plate" to hold the rings because it designed to fit exactly onto its own type of vehicle.
My suggestion is you go ahead put those rims onto your car. Sometimes, it doesn't create any vibration. If it does have vibration then you can try to put those rings on.
Just make sure when it time to rotate don't let anyone else touch your rims because only you would be careful enough to make sure the rims fit tightly in the middle. The Hub Centric rings were designed to make sure the rims put onto the hub center bore is exactly in the middle of the hub center bore.
Good luck.
Old 12-12-2007, 05:53 PM   #9 (permalink)
Not-So-New TN User
Netforcer's Avatar
Gameroom cash: $225700
so hard to be different.. hahaha... you don't really need hubcentric rings... if you can center the rims perfectly
My Partial Partout!!!
Photo Album
Old 12-12-2007, 05:56 PM   #10 (permalink)
hey lammy, i think i know what your saying and i think my wheels do have that little lip on the inside, ill take some pics when i get off work.
Old 12-12-2007, 06:21 PM   #11 (permalink)
and what do i need to ensure that i mount my wheels centered correctly? just a torque wrench? should i get the tires mounted and balanced then just go home and re torque the wheels?
Old 12-12-2007, 06:31 PM   #12 (permalink)
Here and there...
What you should do is have the tires mounted and balanced then ask if you can put those wheels on yourselve or at least stand next to the guys with a torque wrench. For our Camry, it is recommended as 77 ft/lbs. I use 80 ft/lbs but it's just me.
Old 12-12-2007, 08:50 PM   #13 (permalink)
Old 12-12-2007, 09:29 PM   #14 (permalink)
JAKSTER's Avatar
View JAKSTER's Photo Gallery
Clark it looks like the ring is in that wheel already so what?????? Maybe you could get a machine shop to cut something to fit from a piece of pipe just a thought. Its not a tough cut on a lathe I would guess you could get them made for $50 or less maybe in stainless.
TUNER OR LATER
JAKSTER is offline   Reply With Quote
Old 12-12-2007, 09:48 PM   #15 (permalink)
It's hot out here
Drks1de's Avatar
View Drks1de's Photo Gallery
Why would you put Mazda wheels meant for a SUV on a Camry in the first place?
Toyota Camry SE 3.5L V6...sold!
Drks1de is offline   Reply With Quote
Stuck - removing RH driveaxle from bearing mount awmccready Camry & Solara Lounge 12 04-16-2011 06:53 PM
are fog lights really needed to be on when driving???? *rant* chronoti Off Topic 16 10-04-2004 07:32 PM
An American's Guide to Driving in Canada brink General Discussion 29 07-20-2004 05:25 PM
newbie driving me crazy! smokey8890 Introduce Yourself Here 4 10-01-2002 10:40 AM
