Bleeding Brake Caliper - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-12-2007, 03:50 PM   #1 (permalink)
Registered User
View qprint's Photo Gallery
Changed my rear pads and bled the cailper to get rid of old fluid in the calipers. Now i get a soft pedal when braking. I used a Hand Vacuum Pump to bleed the calipers starting at the passenge rear. I noticed a lot of air coming out at first. I always checked the reservior was topped up.
I then saw tiny bubbles thinking air is coming from the bleeder screw itself, so i put a little grease around the bleeder screw and I still got tiny bubbles appearing in the line.
I switched to the helper method [ friend pumps the brake pedal several times, holds it down and I open the bleeder and check let the air out].
It doesnt end, air just keeps coming out and I go for a drive and the pedal is a little lower and soft.
Any suggestions to how to bleed these rear disk brakes ?
qprint is offline   Reply With Quote
Old 12-12-2007, 03:52 PM   #2 (permalink)
ASE Master Technician
JSM1284's Avatar
Gameroom cash: $186325
View JSM1284's Photo Gallery
iBLEEDING
HINT: If any work is done on the brake system or if air in the brake lines is suspected, bleed the air from the system.
NOTICE: Wash off the brake fluid immediately if it comes into contact with a painted surface.
  1. FILL RESERVOIR WITH BRAKE FLUID Fluid: SAE J1703 or FMVSS No. 116 DOT3
  1. BLEED MASTER CYLINDER HINT: If the master cylinder has been disassembled or if the reservoir becomes empty, bleed the air from the master cylinder.
    1. Remove the air cleaner assembly with hose.
    2. Disconnect the brake lines from the master cylinder. SST 09023-00100
    3. Slowly depress the brake pedal and hold it.
    1. Block off the outer holes with your fingers, and release the brake pedal.
    2. Repeat (c) and (d) 3 or 4 times.
    3. Install the air cleaner assembly with hose.
  1. BLEED BRAKE LINE
    1. Connect the vinyl tube to the brake caliper.
    2. Depress the brake pedal several times, then loosen the bleeder plug with the pedal held down.
    3. At the point when fluid stops coming out, tighten the bleeder plug, then release the brake pedal. Torque: 8.3 Nm (85 kgf-cm, 74 inch lbs.)
    4. Repeat (b) and (c) until all the air in the fluid has been bled out.
    5. Repeat the procedure to bleed the air out of the brake line for each wheel.
  1. BLEED BRAKE ACTUATOR ASSY (W/VSC) NOTICE: After performing the usual air bleeding in the brake system, if the height or feel of the brake pedal cannot be obtained, perform air bleeding in the BRAKE actuator assy with a hand-held tester by following procedures below.
    1. Depress the brake pedal more than 20 times with the engine off.
    1. Connect the hand-held tester to the DLC3, then turn the ignition switch to the ON position. NOTICE: Do not start the engine.
    2. Select "AIR BLEEDING" on the hand-held tester. HINT: Please refer to the Hand-Held Tester Operator's Manual for further details.
    3. Bleed the air out of the regular brake line in "Step 1: In- crease" on the hand-held tester display. NOTICE:
    • Perform the air bleeding by following the steps displayed on the hand-held tester.
    • Make sure that the brake fluid in the master cylinder reservoir tank does not become empty.
(1)Connect the vinyl tube to either one of the bleeder plugs.
(2)Depress the brake pedal several times, then loosen the bleeder plug of one of the above wheels with the pedal depressed.(3)When fluid stops coming out, tighten the bleeder plug, then release the brake pedal.(4)Repeat (2) and (3) until all air in the fluid is completely bled out.(5)Tighten the bleeder plug completely.
Torque: 8.3 Nm (85 kgf-cm, 73 in.-lbf) (6)Repeat the above procedure to bleed the air out of the brake line for each wheel.
    1. Bleed the air out of the suction line in "Step2: Inhalation" on the hand-held tester display. NOTICE:
(1)Connect the vinyl tube to the bleeder plug at the right front wheel or the right rear wheel and loosen the bleeder plug.(2)Operate the BRAKE actuator assy using the hand- held tester to bleed the air.NOTICE:
  • The operation stops automatically in 4 seconds.
  • At this time, be sure to release the brake pedal.
(3)Check that the operation has stopped, by referring to the hand-held tester display.(4)Repeat (2) and (3) until all the air in the fluid is completely bled out.(5)Tighten the bleeder plug completely.
Torque: 8.3 Nm (85 kgf-cm, 73 in.-lbf) (6)For the rest of the wheels, bleed the air in the same way as stated in the above procedure.
    1. Bleed the air out of the pressure reduction line in "Step 3: Decrease" on the hand-held tester display. NOTICE:
    • Perform air bleeding by following the steps displayed on the hand-held tester.
(1)Connect a vinyl tube to either one of the bleeder plugs.(2)Loosen the bleeder plug.(3)Using the hand-held tester, operate the BRAKE actuator assy using hand-held tester, completely depress the brake pedal and keep it.NOTICE:
  • The operation stops automatically in 4 seconds. When performing this procedure continuously, an interval of at least 20 seconds is required.
  • When the operation is completed, the brake pedal slightly goes down. This is a normal phenomenon caused when the solenoid opens.
  • During this procedure, the pedal seems heavy, but completely depress it so that the brake fluid comes out from the bleeder plug.
  • Be sure to keep depressing the brake pedal. Never depress and release the pedal repeatedly.
(4)Tighten the bleeder plug, then release the brake pedal.(5)Repeat (2) to (4) until all the air in the fluid is completely bled out.(6)Tighten the bleeder plug completely.
Torque: 8.3 Nm (85 kgf-cm, 73 in.-lbf) (7)Repeat the above procedure to bleed the air out of the brake line for each wheel.
    1. Bleed the air out of the regular brake line again in "Step 4: Increase" on the hand-held tester display. NOTICE:
(1)Connect the vinyl tube to either one of the bleeder plug.(2)Depress the brake pedal several times, then loosen the bleeder plug of one of the above wheels with the pedal depressed.(3)When fluid stops coming out, tighten the bleeder plug, then release the brake pedal.(4)Repeat (2) and (3) until all the air in the fluid is completely bled out.(5)Tighten the bleeder plug completely.
  1. CHECK FLUID LEVEL IN RESERVOIR
    1. Check the fluid level and add fluid if necessary. Fluid: SAE J1703 or FMVSS No. 116 DOT3
Your source for Gen6 TSX Retro's (PM for details)
2005 Lexus ES330
2007 Camry SE V-6 Titanium(SOLD)
Moonroof, Navi, Sport Leather, Floor Mats, Phillips 4300k HID, 15% Tint, Silverstar Turn signals
“My friends call me ‘The Cane.’ Even before I messed up my leg.” ~Dr. Gregory house
JSM1284 is offline   Reply With Quote
Old 12-12-2007, 04:42 PM   #3 (permalink)
View Camry5genrocks's Photo Gallery
I have few questions JSM. What do they mean by SST 09023-00100?, and what size vinyl tube will fit the bleeder plug?. Do you happen to have a picture of the bleeder plug? Thanks
Camry5genrocks is offline   Reply With Quote
Old 12-12-2007, 04:48 PM   #4 (permalink)
JSM1284's Avatar
Special Service Tool, Basically a line wrench.
The Bleeder plug is the Bleeder screw on the back of the calipers. Im not absolutely sure, But I think 3/16" tube would fit.
2005 Lexus ES330
Rear disc brake question (caliper)... Surfslinger 5th & 6th Generation (2002-2006 & 2007-2011) 11 03-26-2008 06:51 PM
Brake Noise FirstCamry 5th & 6th Generation (2002-2006 & 2007-2011) 7 10-30-2007 02:40 PM
Brake Caliper problem qprint Camry & Solara Lounge 17 10-10-2007 08:17 PM
Changing Front Brake Caliper bcking00 Archived Corolla threads 2 05-11-2005 04:36 PM
Really newbish question on missing bolt for drivers side brake caliper Blek General Discussion 4 07-24-2004 01:06 AM
