finding right tire size - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-12-2007, 11:27 PM   #1 (permalink)
05 CAMRY
BALDY517's Avatar
View BALDY517's Photo Gallery
Gen5 finding right tire size
i bought 08 is 350 rims and i need some help on finding the right tire size for gen 5 camry so it wont rub or anything like that thanks guys help me out
BALDY517 is offline   Reply With Quote
Old 12-12-2007, 11:55 PM   #2 (permalink)
niko3257's Avatar
View niko3257's Photo Gallery
Gen5
http://www.rims-n-tires.com/rt_specs.jsp
here ya go. simple type in your stock size and then
type in a size for the 18 the is the closest to stock.
very easy. i love this thing
07 CAMRY CE
02 RC51/SP2
niko3257 is offline   Reply With Quote
Old 12-13-2007, 12:23 AM   #3 (permalink)
Here and there...
Gameroom cash: $153229
iTrader Score: 6 reviews
View lammydi's Photo Gallery
Your IS350 rims is the same specs as my GS430 rims. You can go with either 225-45-18 or 235-45-18. I currently have 235-45-18 on my car.
Old 12-13-2007, 12:34 AM   #4 (permalink)
05 CAMRY
BALDY517's Avatar
Gen5 rim size
hey man thanks for the help this really helps me out alot
Old 12-13-2007, 12:41 AM   #5 (permalink)
05 CAMRY
BALDY517's Avatar
you mean i can get 225 45 18 or 235 45 18 all around
Old 12-13-2007, 01:10 AM   #6 (permalink)
Here and there...
Yes, you should get the same size tires all around but assuming you bought all 4 wheels are same size.
The IS350 front wheels are 18x8 and the rear are 18x8.5 because the IS350 is rear wheel drive.
Did you buy all 4 wheels the same size?
Old 12-13-2007, 01:31 AM   #7 (permalink)
steveyhustle's Avatar
View steveyhustle's Photo Gallery
ya 18s should b easy to fit since i got 20s on mine and dont rub
Catch me in ya city,
Sittin Pretty,
You know im shinin' dog!
steveyhustle is offline   Reply With Quote
Old 12-13-2007, 01:42 AM   #8 (permalink)
05 CAMRY
BALDY517's Avatar
Gen5 rim size
thats the thing i got a real full set 18x8 and 18x8.5. and fa show there should be no rub since i got no 20's
Old 12-13-2007, 01:44 AM   #9 (permalink)
Here and there...
The diameter of the rims (18,19,20") is only one of many factors that make rims fit or not fit. There are width, offset, lug pattern, center bore...
Old 12-13-2007, 01:59 AM   #10 (permalink)
View DiLan's Photo Gallery
Where did you get your IS350 rims from? Those r the rims I want too :P
1990 Camry LE V6 25th Anniversary Edition
DONE:Sony Xplod 800W Amp(XM-1252GTR) w/ Dual Kicker Subs, Alpine CDE-102 Deck, New Eliminator Battery, Keyless Entry
TO DO:Intake adapter, fix wheel well rust
*SOLD*2007 Camry I4 SE Alpine White
http://www.cardomain.com/ride/2571595
DiLan is offline   Reply With Quote
Old 12-13-2007, 02:15 AM   #11 (permalink)
05 CAMRY
BALDY517's Avatar
Gen5 rim size
i understand that there are other factors but i have this thing called wheel/ tire size calculator and i calculated it the tire size and rim size for 8 and 8.5 and it says it fits 18x7 to 18x9 here is the site you can do this for youself to see for your self http://www.rims-n-tires.com/rt_specs.jsp check that out. the rims i got were from a guy in sacramento took me a while to get up there 1hr and 30 min dat was a long drive you should check craigslist cuz that was how i found mines
Old 12-13-2007, 09:24 AM   #12 (permalink)
Here and there...
You should be fine with those tires 225 or 235-45-18. The links above is for your tires to fit the rims. My comments about "other factors" was referring to Steve's comment about 18" and 20" rims.
A head up for you, since you'll put on a wider rims in the rear with your front wheel drive, you will have more understeering because of that.
Wider rims in the rear was design to control oversteering for rear wheel car.
To do it right, you almost want to put the wider rims in the front. If you have a V6 then the problem will be even more noticeable.
Old 12-13-2007, 11:05 AM   #13 (permalink)
bigloubumpin's Avatar
Gameroom cash: $151645
View bigloubumpin's Photo Gallery
first time seeing a site like that,kool
bigloubumpin is offline   Reply With Quote
Old 12-13-2007, 07:14 PM   #14 (permalink)
View clarkgrizwald's Photo Gallery
i seriously doubt you can swing a 8.5 width rim in the front, guess anything is possible. i think the wider ones are gonna have to be in the back. are they +45 offset? i was gonna go with the is rims but everyone and theyre moms have them. plus there is the headache of dealing with the staggered.
clarkgrizwald is offline   Reply With Quote
Old 12-13-2007, 07:23 PM   #15 (permalink)
*thread jack* on a related note, does anyone else think i might have to go with a 215 wide tire instead of 225 because my offset is +50?
biggest tire size on stock mini 05+ Wolfman 2nd Generation (2005+) 9 04-03-2007 12:45 AM
correct tire pressure changes with size? fredster34 Camry & Solara Lounge 8 04-21-2006 04:38 PM
WOW 07 Canadian Camry LE with FULL SIZE spare tire!!!! ben24 5th & 6th Generation (2002-2006 & 2007-2011) 9 03-06-2006 08:05 PM
tire size? andriod8000 1st Generation (1995.5–2004) 1 03-01-2006 08:34 PM
Tire size comparison calculators HoustonHokie 2nd Generation (2005+) 4 02-24-2006 01:22 AM
