Here is how you check if you need to change your struts... park your car on flat surface and have both hands push down (on the hood). make sure both your hands push down the area that struts position on your car. make sure good amount of pressures push down, then take both hands off the hood. now, you should see the struts eject (forces) upward (1-2 times) then stop...if the force eject upward, more than 3 or more...you consider a new struts...also, visual inspect for abnormal sound (squeeze sound) and wear.
I hope this will helps... Normally, the front struts go bad quicker than the rear...If you reverse your car out of your drive way and if the underneath (front the car) of your car keep hit the cement for every time u got out (slop/deep hill) drive way. this tell your struts are bad.. need new struts..the struts have air internal.. My 96 toyota camry..did that way for every time I reverse out (slop/deep hill), the front underneath kept hit the cement.. . I replaced front struts...the problems went away.
Reason: Edited version
