I got a 2003 camry Se V6, i recently just installed a trd drop in air filter. I believe i ran in to a problem. i can't seem to place the filter cover box to cover the hold filter. i can still see the red rubber from the air filter.
I just went out and looked at mine. It looks nearly identical to yours on both ends. I also know that mine is sealing perfectly. As long as it's seated properly in the base you are just fine.
I had an air filter placed incorrectly on my 2000 Camry. The gasket was pinched and didn't seal on a 1 cm section. When I took the filter cover off, the portion with the hose going to the throttle body, I could clearly see a small dust trail from where the pinched portion of the seal was located. I had it like that for about 3000 miles or so.
I doubt it caused much long term damage but since the car was totaled a few months later, I'll never find out either.
Check up on it in a few thousand miles for dirt or dust getting past.
For now, you can double check everything is seated properly. If it is, it should not be a problem.
2007 Camry 2.4L 5M
