Brake Squeak - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-15-2007, 01:45 PM   #1 (permalink)
geoff5093's Avatar
View geoff5093's Photo Gallery
Brake Squeak
Before anyone starts telling me to search, I know there have been a few threads on the topic and there are TSB's for the problem. I first only heard the squeak when baking up and only under certain circumstances such as how hard I pressed on the brakes. Now it does it virtually every time I first drive the car after it's been sitting for a while, both going in reverse and driving forward.
This leads me to my actual question. Is this just a noise issue, or are the brakes actually worn down to the point of needing replacement's already? I don't have a huge problem with just the noise, but I want to make sure that it's not causing unnecessary brake pad wear or any actual damage.
BTW, I have about 16,400 miles on the car.
geoff5093 is offline   Reply With Quote
Old 12-15-2007, 02:05 PM   #2 (permalink)
"Two Tacos"
west467's Avatar
View west467's Photo Gallery
Same here... I think the TSB adds some shims to the brakes to stop the noise. Take your front wheels off, I bet the pads are OK. It is just another anoying Toyota quality issue!!
west467 is offline   Reply With Quote
Old 12-15-2007, 02:07 PM   #3 (permalink)
Gameroom cash: $303755
I had this problem with my 07 when new. Having TSB done solved the problem. I suggest you take it to your dealer and ask to have the TSB done, or at least get on notice with your dealer that the problem exists. The TSB really just replaces the brake pad holding clips in the caliper with some newer/tighter ones. It's not a big deal. I doubt your pads are worn at 16,000 miles.
Mike
Old 12-15-2007, 02:26 PM   #4 (permalink)
View AYC_SportsFan's Photo Gallery
What exactly is TSB?
AYC_SportsFan is offline   Reply With Quote
Old 12-15-2007, 02:36 PM   #5 (permalink)
Baby's got a new skirt
ebumdude's Avatar
Gameroom cash: $180662
iTrader Score: 7 reviews
View ebumdude's Photo Gallery
Gen6
Technical
Service
Bulletin
It's something Toyota comes out with to fix a problem that a lot of people have.
- 07' Camry: LED interior/JDM fogs/Lighted stainless door sills/White cathode footwells front, back & trunk/Kenwood DDX6019/Rockford Fosgate P400-4/TMA T1000/(2) 10" Polk Momo 2104/Polk MM6's front's/Polk db6501's rear's/2.0 farad Tsunami Cap/18" Primax /6000k HID/Tein's
-09' Venza
ebumdude is offline   Reply With Quote
Old 12-15-2007, 03:47 PM   #6 (permalink)
Right, but we have to find the issue within this "bulletin," correct?
Old 12-15-2007, 05:14 PM   #7 (permalink)
Twin & (1 of 8)
Luna2's Avatar
Gameroom cash: $455050
View Luna2's Photo Gallery
Correct!!!!!!
Most owners are not aware of the TSB's, and think their vehicle is normal, because the service department said it was...........
2011 XLE, I4, AT, Sliver, New May 1, 2010
MFG 02/25/2010
Stock, Shucks!
"Kinda Hard to ID in a Parking Lot"
Luna2 is online now   Reply With Quote
Old 12-15-2007, 06:03 PM   #8 (permalink)
Where exactly can I obtain a copy of this "bulletin"?
Old 12-15-2007, 06:15 PM   #9 (permalink)
Gameroom cash: $203160
View CamrySExxx's Photo Gallery
TSB 2007 Camry Listing with PDFS!
The new camry had so many problems it deserved its own stickied thread of all its bulletins
Anyways my breaks DID squeak for a bit at low speeds than all of a sudden it stoped :S i was going to get the TSB done too but i guess not. The only thing i still have to do is the hesitation one.
CamrySExxx is offline   Reply With Quote
Old 12-15-2007, 06:27 PM   #10 (permalink)
'07 XLE
Gameroom cash: $283530
View njerald's Photo Gallery
Gen6
Who knows!
Inspect them or have someone do it.
Old 12-17-2007, 01:49 PM   #11 (permalink)
geoff5093's Avatar
I plan on making an appointment with the dealer to get it checked out, however I'm trying to determine if it only happens after the car sits for several hours, or just 30 minutes or so. Because I really don't want to leave the car at the dealer overnight just for them to say they never found a problem.
I also recorded a quick video:
Old 12-17-2007, 06:39 PM   #12 (permalink)
2003 Camry Speedster
View IPDaily's Photo Gallery
Gen6
you know honestly geoff, i wouldn't bother taking it to the dealer, it's nothing really... both of my camry's squeak when you let off the brakes really slowly, and the brake pads aren't worn, and the rotors definitely aren't warped... i think it's just one of those quirks with camry's, there's nothing wrong with it... if it would make you feel any better, maybe next time you take it in for service, ask them to lubricate the breaks?
2003 Toyota Camry XLE V6, 18x7.5" ASA rims +40mm offset, Bridgestone Potenza Tires 225/45/18, H&R Sport Springs, TRD Exhaust/Strut Tower Brace/Rear Sway Bar, Wood Steering Wheel, 20% LLumar Tint
2007 Toyota Camry SE V6, Sport Leather
IPDaily is offline   Reply With Quote
Old 12-17-2007, 06:58 PM   #13 (permalink)
"Two Tacos"
west467's Avatar
Yep, sounds like mine, and looks like mine. I think I will live with it untill the pads need changing, then I will buy the OEM clips, and fix it myself. The more you can keep the dealer away from your car, the better off it will be.
Old 12-17-2007, 08:48 PM   #14 (permalink)
geoff5093's Avatar
As I mentioned before I'm not really that worried with just the sound, as it usually only happens when I haven't driven the car for a few hours. I just wanted to make sure that it wasn't causing any kind of premature brake pad/rotor wear.
If my car is still under 36K miles and the brake pads need to be replaced, i'll ask them then to complete the TSB.
Old 12-22-2007, 11:23 PM   #15 (permalink)
geoff5093's Avatar
Well now I notice that there is a squeal when I'm just driving. When I tap on the brake pedal it goes away, but then comes back in a little bit.
It sounds like the pad-wear indicator, although I hope thats not the case since I only have 17K miles.
94 Camry brake warning light eaglemtn 3rd & 4th Generation (1992–1996 & 1997–2001) 25 05-04-2012 11:57 AM
Brake problem smcinrox Archived Corolla threads 0 04-29-2007 09:01 AM
DAM U KSPORT & Your Big Brake Kit... trninhds 3rd & 4th Generation (1992–1996 & 1997–2001) 4 04-09-2007 02:44 PM
3rd brake light fuse popping gameguru1360 Archived Corolla threads 4 03-15-2007 03:21 PM
Squeak from brake pedal.. Novice_cardude Camry & Solara Lounge 12 04-12-2006 05:12 PM
