1. type proper sentences so we can understand you better
2. are u saying that u want the car to roll by itself while in drive and not giving it any gas? if thats the case, check your tire pressure. also check that your brake calipers arent sticking. i really dont see a problem with this as you dont want the car to move a lot by itself
and parking brake adjustment is key as well....if the parking brake cable is adjusted to tight on the rear parking brake shoes, the car will grab too easily and wont roll as easiely, as if the parking brake is set. and the light will not be dispalyed either.
If you don't want to sell your car on ebay and get a Malibu, just ask Bruce. I'm sure he knows.
Old Car: '03 Toyota Camry LE
New Car: '04 Black ES330 (Aftermarket sound/navigation system installed)
Always got something else in mind...
remove the intake tube....removal can be found at www.camrymanuals.com
download the gen 5 (2002-2006) manual and search for intake tube removal
buy yourself a can of throttle body cleaner and spray it sparingly inside the throttle body and be sure to get inbetween the butterfyl valve and whre it contacts the inside of the TB by moving the valve itself....now reinstall the intake tube and youre set
I think he just wants a faster roll. yeah clean your TB, check tire pressure. reset ECU, see if it helps. If you've never cleaned your TB before........yeah, do it.
-Custom 2.5in Cat-back Exhaust + Borla Muffler + Weapon R Dragon Intake + TRD Rear Sway Bar + TRD Springs + TRD Front Strut Brace
Whats the deal with spraying the TB cleaner sparingly into the TB?
Anything bad if I give it a good spray in 5 second bursts...wait a few mins, then again spray once...wait a few mins and start rev the motor for a few...
Also I got the cheap value craft TB/Crab cleaner, Can I use that?.
crab cleaner shouldn't be in your car.. j/m
i just spray some, start scrubbing, clean up, repeat
