No ABS - gone - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-16-2007, 08:52 PM   #1 (permalink)
View poke708's Photo Gallery
Gen6 No ABS - gone
My wife has camry 04 4cyl
she dint have a problem till now
after first snow she said she has problem with car and old camry 89 was better then new one
i took car drove it and i discovered that ABS is gone, it doesnt work
there is no abs or check engine light on
there was only MAINT REQ light which i removed with key and push button method
car has only 28k miles
also before you start engine when oil check engine and other lights light up there is no ABS light
any help would be apriciated
Thank You and Merry Christmas to all
poke708 is offline   Reply With Quote
Old 12-16-2007, 09:17 PM   #2 (permalink)
The Connoisseur
CharmCityES's Avatar
first of all, you have a gen 5 camry (2002-2006)
is it just not working or non existant?
because the ABS light would come on if it wasnt functioning properly
gen 5 camry LE 4cyl models did not come standard with ABS. it was optional and not equipped on most LE 4cyl models.
The "Executive Sedan"
Old 12-16-2007, 09:24 PM   #3 (permalink)
touringcamry's Avatar
Gameroom cash: $510625
+1
ABS was standard only on XLE and all V6
2007 Camry 2.4L 5M
Old 12-16-2007, 09:47 PM   #4 (permalink)
Ok its Camry '04 LE 4cyl with sunroof, power seat, ABS
She has (had ABS) it was working
Yesterday I discovered it does not work
This morning i check if ABS light goes on when you turn key but it doesnt
Can it be 1 of the fuses or relays ? (i want to fix light first)
Thank You for any help
Old 12-16-2007, 11:01 PM   #5 (permalink)
'07 XLE
Gameroom cash: $283530
View njerald's Photo Gallery
Gen6
Check the fuses...
Have the skid control ECU checked for DTC's.
ABS light on, code 36, 71 bronzemaxell 3rd & 4th Generation (1992–1996 & 1997–2001) 0 08-20-2006 11:28 AM
engine/ABS light help.... trninhds Camry & Solara Lounge 11 06-18-2006 12:06 AM
Rading ABS Codes from 95 Toyota Camry satexascamry 3rd & 4th Generation (1992–1996 & 1997–2001) 12 04-09-2005 11:05 PM
abs need abs pad? neck Camry & Solara Lounge 7 03-22-2004 10:56 PM
