My feet are cold - Page 2 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-18-2008, 10:47 AM   #16 (permalink)
timky1
View thebutcherking's Photo Gallery
Cool Finally Warm feet!
I finally took the dash apart to fix the air distribution servo...what a mess! The actual cause of the problem was that the lever which controls the floor vent door, is a compound lever and the two levers had separated. The way the air distribution works, there are 3 separate controls, one for the defrost, one for the dash vents, and one for the floor, and each has a pin that fits into the servo's little maze wheel. Finding the problem, including disassembly of the dash only took about 3 hours. Trying to get the servo wheel repositioned onto all 3 pins so that it was functional, took another 3. Time well spent if you live in a cold climate! So with that issue down, there is only the catalytic converter code, and the belt adjuster to deal with, but that is another post.
thebutcherking is offline   Reply With Quote
Old 03-03-2008, 07:00 PM   #17 (permalink)
View wayne pruden's Photo Gallery
Perhaps I can help
Originally Posted by GoldenTacoMan View Post
I have the exact same problem (and exact same model of Camry). I was able to reach my hand up under the driver's side dash and feel the servo motor. As I turn the vent control knob I can feel the servo "disk" apparently spinning cleanly through each of the settings. This leads me to believe that there is a blockage in the foot vent somewhere. Can anyone tell me where such a blockage might occur and how I can get my little hand up into wherever that may be?
I just fixed mine. After reading this thread it took me about 2 minutes, maybe 3. You will have to bend, in ways we were not intended to, and get your head under the dash by the gas pedal. Look up and you will see the servo motor, reach over and activate the control knob and you will see it move a little white plastic arm attached to the motor, this arm will move down towards another little white plastic arm, the top arm should be connected to the bottom arm by slipping the pin on the top arm into the slot on the bottom arm. You will have to spread them a little to accomplish this (I used a flat bladed screwdriver).
wayne pruden is offline   Reply With Quote
Old 03-08-2008, 11:08 AM   #18 (permalink)
timky1
Angry Still warm but...
My celebration was a little premature apparently, now the control is stuck between floor, floor/defrost and defrost.
Some of us can't bend that way any longer!
Old 03-08-2008, 11:34 AM   #19 (permalink)
Hey now
Ha, ha, I guess I should have told you, I havn't been 21 for almost 45 years. You want to talk about bending?????
Pretty soon spring will be here and I can fool around with my favorite car....57 Buick Roadmaster Riviera
Cold Weather Tacoma? Tacorossa 2nd Generation (2005+) 82 02-07-2011 01:33 PM
cold start injector won' fire...3vz-fe mcgowaw 3rd & 4th Generation (1992–1996 & 1997–2001) 1 12-01-2006 03:41 PM
AC cold from center vents, warm on side vents 1999 XLS stehrster 1st Generation (1995-1999) 2 08-31-2006 01:37 AM
A/C Not blowing Cold Air garrand3006 Archived Corolla threads 4 08-09-2006 04:08 PM
