My feet are cold - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-18-2007, 12:44 PM   #1 (permalink)
timky1
View thebutcherking's Photo Gallery
USA My feet are cold
My heater control will not switch to the floor setting. No big deal in the summer, but it does get a little cold in the winter here. I took it to my local dealer, charged me $90 to give me an estimate of $700 to fix. When I bought the car, it had the problem, the used car guy at the dealer fixed it no problem, but then it returned. Anyone know what it is??? My feet will appreciate it.
thebutcherking is offline   Reply With Quote
Old 12-18-2007, 12:56 PM   #2 (permalink)
ASE Master Technician
JSM1284's Avatar
Gameroom cash: $172825
View JSM1284's Photo Gallery
Didnt the dealer tell you what was wrong? Does it blow out the vents on the dash? It may be a "Mode" door. What year is your car?
Your source for Gen6 TSX Retro's (PM for details)
2005 Lexus ES330
2007 Camry SE V-6 Titanium(SOLD)
Moonroof, Navi, Sport Leather, Floor Mats, Phillips 4300k HID, 15% Tint, Silverstar Turn signals
“My friends call me ‘The Cane.’ Even before I messed up my leg.” ~Dr. Gregory house
JSM1284 is offline   Reply With Quote
Old 12-18-2007, 01:45 PM   #3 (permalink)
timky1
Sorry, I fogot to add that the the car is a 2002 LE, 2.4L.
Nope, the dealer said that they didn't know what it was.
The only way I can get heat is through the vents in the dash, or the defroster, both of those seem to work okay.
If I switch to the floor setting, or the defroster/floor setting, I get a loud sound, like a lot of air moving through a small space.
Old 12-18-2007, 01:53 PM   #4 (permalink)
JSM1284's Avatar
The "Air outlet control servomotor(Mode servo)" is most likely the problem.
This is what directs the air to the position requested whether it be defrost, vents, floor, etc. The servo may not be moving the door all the way to the floor position, or something could be caught in the duct preventing it from moving to the floor position.
2005 Lexus ES330
Old 12-21-2007, 05:51 AM   #5 (permalink)
timky1
Question Thanks for the schematic
Any tips on getting access?
Old 12-21-2007, 04:41 PM   #6 (permalink)
Not-So-New TN User
Netforcer's Avatar
Gameroom cash: $224200
Just wear socks... wool is nice
My Partial Partout!!!
Photo Album
Old 12-21-2007, 04:53 PM   #7 (permalink)
JSM1284's Avatar
Crawl under the driver side dash to get to the servo
2005 Lexus ES330
Old 12-24-2007, 02:35 PM   #8 (permalink)
timky1
Cool Netforcer
Merry Christmas!
Old 01-04-2008, 06:45 AM   #9 (permalink)
View GoldenTacoMan's Photo Gallery
I have the exact same problem (and exact same model of Camry). I was able to reach my hand up under the driver's side dash and feel the servo motor. As I turn the vent control knob I can feel the servo "disk" apparently spinning cleanly through each of the settings. This leads me to believe that there is a blockage in the foot vent somewhere. Can anyone tell me where such a blockage might occur and how I can get my little hand up into wherever that may be?
GoldenTacoMan is offline   Reply With Quote
Old 01-04-2008, 01:26 PM   #10 (permalink)
'07 XLE
Gameroom cash: $283530
View njerald's Photo Gallery
Gen6
Damper not attached to the servo, loose on the damper shaft...
Good time to use your extended warranty and have your dealer tear the dash apart and fix for ZERO $$$$$$$.
Old 01-04-2008, 01:35 PM   #11 (permalink)
A brilliant plan! Except I have over 120,000 miles on it (I commute over 60 miles each way to work) so no more warranty.
Trust me, if having someone else do this for free were an option, I would not be posting in forums to figure out how to do it myself
Old 01-05-2008, 11:34 AM   #12 (permalink)
timky1
Amen to that!
Perhaps Toyota, with their ratings slipping, might consider launching a campaign to fix this issue!
Between surgery, the holidays and the weather, I haven't had a chance to fix mine. I do remember that the dealer said that the servo was making full travel.
I did get a new pair of wool socks for Christmas!
I also have a new problem, should probably post it elsewhere, but since I am hear...
I am getting a P0420 code...catalytic converter ya ya ya, when the mornings are below 40. If I reset the code, and we have a warm day, it does not come on until it gets cold again. I know there is a TSB out there for this one. All this just when I was thinking Toyota was better than Honda.
Old 01-08-2008, 01:40 PM   #13 (permalink)
We are like Camry twins or something. Mine just started spitting out the P0420 too. I'm going to try to get it looked at this weekend to see if it's the cat. or a sensor.
Are you trying to sell yours? I'm trying to sell mine and I think it feels betrayed and that's why it's acting out
Old 01-08-2008, 02:02 PM   #14 (permalink)
timky1
Angry Could be Camry Twins
What a deal...I also commute 60 miles each way...ok, more like 58, but close enough!
On the P0420, was it a cold day? There is a TSB out there for the P0420 showing up when it is cold. The fix involves some gasket replacement, or something like that. Not sure what the TSB# is, but it is for 2002 Camrys with the 2.4L. Course, dealer won't fix that either.
Think you can buy a new Camry from Honda? They have better service!
No, I'm not selling...bought the car with 56K, now at about 140K and only these 2 problems (if you don't count the belt adjuster rattle...also not covered).
Before someone says it, I had an extended warranty, ran out about 10K ago.
Old 01-08-2008, 02:12 PM   #15 (permalink)
Funny you should mention it. I just went back and looked and it was in the 30's all day that day. I'll have to look into that.
My car's almost at 125K and these are the only two problems I've had also.
Cold Weather Tacoma? Tacorossa 2nd Generation (2005+) 82 02-07-2011 02:33 PM
cold start injector won' fire...3vz-fe mcgowaw 3rd & 4th Generation (1992–1996 & 1997–2001) 1 12-01-2006 04:41 PM
AC cold from center vents, warm on side vents 1999 XLS stehrster 1st Generation (1995-1999) 2 08-31-2006 02:37 AM
A/C Not blowing Cold Air garrand3006 Archived Corolla threads 4 08-09-2006 05:08 PM
