wheel changing question.. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-21-2007, 12:12 AM   #1 (permalink)
View clarkgrizwald's Photo Gallery
im getting my new wheels and tires put on tomorrow. im headed home for christmas on saturday. i was thinking of putting my old wheels back on before i go home so i can avoid putting 600 miles on my new tires. but i dont know if i will or not. as far as changing the wheels, just use a torque wrench? is there anything else i need to know about taking and putting wheels back on a car?
clarkgrizwald is offline   Reply With Quote
Old 12-21-2007, 12:18 AM   #2 (permalink)
The Connoisseur
CharmCityES's Avatar
tighten all the lugs to 80lbs with a torque stick
21mm lug nuts for camry
make sure if u have wheel locks to not lose the key
if u have directional tires make sure theyre going the correct directon
its pretty self explanitory
The "Executive Sedan"
Old 12-21-2007, 12:25 AM   #3 (permalink)
Here and there...
Gameroom cash: $153229
iTrader Score: 6 reviews
View lammydi's Photo Gallery
If you decide to go on a long trip with the new rims+tires then make sure you give it a test drive at different speed and also brake at different speed to see if you can feel any vibration at all. This way you are not driving 600 miles with rims+tires that has vibration.
Old 12-21-2007, 12:32 AM   #4 (permalink)
Forgive meee.
liquidi3ladz's Avatar
View liquidi3ladz's Photo Gallery
You could put it off till you get back.
2002 Camry LE I4
liquidi3ladz is offline   Reply With Quote
Old 12-21-2007, 06:17 AM   #5 (permalink)
I callz it like i seez it
View ScrooYoo's Photo Gallery
its pretty simple stuff man. just make sure u retorque your lug nuts to make sure after about 100km anytime you change your wheels.
ScrooYoo is offline   Reply With Quote
Old 12-21-2007, 10:30 AM   #6 (permalink)
yea for the life of me i havent figured out if i need to buy new lugs or not. when i ebay mazda lugs (which is the wheel im putting on) the lugs are the same that i already have. but everyone tells me that i need different lugs than the ones that came on my steelies. however i dont think i do need new ones. but i dont know..
Old 12-21-2007, 10:31 AM   #7 (permalink)
It's Soo Hoo like Yoo Hoo
MrSo0h0o's Avatar
Gameroom cash: $304005
View MrSo0h0o's Photo Gallery
did u get them put on yet?
MrSo0h0o is offline   Reply With Quote
Old 12-21-2007, 10:49 AM   #8 (permalink)
naw its still up in the air firestone got 3 of 4 tires from ups today? they are calling me in 10 to let me know if they got the 4th..
Old 12-21-2007, 10:54 AM   #9 (permalink)
I do all my own stunts
View 07XLE's Photo Gallery
I wouldn't advise using a torque wrench to remove the lugs, use either a big socket wrench or breaker bar (similar to a socket wrench, just no gearing like socket wrenches have), you can mess up the calibration of the torque wrench using it for loosening bolts, only use the torque for installing them. If you must use the torque wrench for loosing the lugs, just make sure you set it to something over 100lb/ft of torque. The torque stick that was referred to in a previous post is for use with impact guns, so unless you have air tools (impact wrench), you'll need the regular torque wrench.
'07 Camry XLE V6, Titanium Silver, Moonroof, Spoiler, JBL Audio, Tint, Car Seat
07XLE is offline   Reply With Quote
Old 12-21-2007, 11:00 AM   #10 (permalink)
Darkside Cut Me!!!
Gameroom cash: $135123
View Hajoca's Photo Gallery
Alloy wheels are usually shank type with a steel washer, or a very wide chamfer (v type seat)
the lug nuts must fit the type of wheel , so if the wheel is of the shank type then you will need new lugs.
Toyota alloy wheel lugs are of the shank type but on the bottom where there is a bulge seat so that it can be used with the steel spare tire.
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
Old 12-21-2007, 12:46 PM   #11 (permalink)
when you say shank are you refering to the kind with washers? im thinking that i might actually need those kind. because when i look closely at the wheel, there are marks there like there has been a washer there.
Old 12-21-2007, 12:52 PM   #12 (permalink)
"Its Camry Bitch"
Dropitmore's Avatar
View Dropitmore's Photo Gallery
more than likely you will need the shank style lug nuts, just dont go to the dealer, cause I went to Toyota and they wanted $12 a lug nut, multiply that times 20 equals raped in the a$$.....see if Firestone or any wheel shop carries them, I ended up going to a wheel shop and got them for $50 for all 20....you could find them a little cheaper than that I would assume, but I was anxious and in a hurry.....
Dropitmore is offline   Reply With Quote
wheel question for 06 tacoma sr5 access cab nads755 2nd Generation (2005+) 5 03-14-2010 04:34 AM
wheel bearing change and other misc question sub0 3rd & 4th Generation (1992–1996 & 1997–2001) 8 04-27-2007 11:38 AM
'07 steering wheel tilt question costanza 5th & 6th Generation (2002-2006 & 2007-2011) 7 03-10-2007 11:26 AM
Question on Mojave wheel for a Taco DUKFVR 2nd Generation (2005+) 1 02-17-2006 09:17 AM
question about TRD steering wheel ID Camry & Solara Lounge 1 08-19-2002 09:49 PM
