Possible Brake Problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-22-2007, 02:30 PM   #1 (permalink)
View SamirKSU's Photo Gallery
I have a 2007 Camry XLE. I had my tires rotated yesterday at the dealership. Now when i hit the brakes to slow down or to make a turn my car starts to vibrate and the steering wheel shakes. I know when you hit the brakes hard the abs kicks in. I called the dealership the service dept. tells me that I am braking hard and it is the abs. I have had my car for over a year and have never had this problem before.
Help please!
SamirKSU is offline   Reply With Quote
Old 12-22-2007, 04:02 PM   #2 (permalink)
Gameroom cash: $303755
First pull over and check all the lug nuts. It would not be the first time someone forgot to tighten all the lugnuts. If they are tight, take it back to the dealership and tell them what you just said here; "that you have been driving this car for over a year and never had this problem before this rotation, so it's not the ABS."
Mike
Old 12-23-2007, 11:57 AM   #3 (permalink)
480 HP 2.4L = lying ricer
TRD VVTi's Avatar
View TRD VVTi's Photo Gallery
Mike
+1
It's possible that they didn't tighten the lugnuts properly and the rotors are warped. It usually doesn't happen that fast though.
2006 Camry LE Special Edition
Old 01-10-2008, 09:14 AM   #4 (permalink)
The initial problem went away, and I did a road trip from KC to SA over the holidays, and I kept on feeling a vibration on the steering wheel when I was braking on the highway to slow down. I hhve 27,300 miles on the car. I just took the car to the dealership they are looking at the problem. I went on a short drive test with a tech and he thought the rotors maybe warped. Is that covered under the warranty, I'm also very surprised that it happened so soon.
Old 01-10-2008, 03:29 PM   #5 (permalink)
View lokiwwm's Photo Gallery
I had to get my rear brakes changed at 24k & 50k... but I do A LOT of driving in stop & go rush hour traffic...
58k miles later... I'm already on a new set of brake pads (all), rotors (all), & calipers (rear). I previously had that same vibration issues at 50k you had (on the freeway at freeway speeds) and it ended up costing me a $1600 brake job later.
I had a leak in my rear brake lines that went all the way inside my calipers, and forced them in the engaged position, prematurely wearing out my brake pads, warping the rear rotors... causing the front brakes to do most of the braking. So... that caused my front rotors to warp as well(Well that's what the service rep told me). Would have been covered by extended warranty, but I didn't buy it... Doh!
Anyway, I digress... Hey, is that black cloud still following my car around?
lokiwwm is offline   Reply With Quote
Old 01-10-2008, 03:34 PM   #6 (permalink)
2008 Camry Hybrid
Yazovets's Avatar
Gameroom cash: $149932
View Yazovets's Photo Gallery
I have the problem you're describing.
If the rotors are warped, then it should be covered by the dealer.
In my case, I had my mechanic friend take a look first. Apparently my rotors are NOT warped but somehow on both front rotors, the surface is uneven.
Therefore, I get the vibration if I start braking lightly or moderately. If I brake harder, then there's reduced vibration.
Anyway...uneven surface will not be covered by warranty (I already asked). I'm just waiting for springtime. I'll have my mechanic perform either a full front brake job or rears as well at that point too.
2008 Camry Hybrid | Magnetic Grey on Grey Leather | Bi-Xenon H1 4300K Retrofit | Italian Hertz Sound System (dash 4" EM 100, front 6.5" ECX 165, rear 6" x 9" ECX 690, 10" ES 250D sub in custom trunk enclosure, HDP5 5-channel amp, 1320W total power) | 4-sensor Rear Parking System | 20% Metallic Tint | Weathertech Floorliners | 17" ASA AR1 Rims | Toyo Garit KX (winter) | Toyo Versado LX II (summer)
Yazovets is offline   Reply With Quote
Should I Skip The Camry Alltogether?!?! hikix 5th & 6th Generation (2002-2006 & 2007-2011) 104 05-29-2008 11:33 PM
AC and brake problem SnowCindy 89-95 Toyota Pickup/Hilux 9 07-28-2007 07:59 AM
Brake light/Shifter interlock problem Keseki 3rd & 4th Generation (1992–1996 & 1997–2001) 4 07-19-2007 02:05 PM
Brake and Tranny Problem fastwrx 3rd & 4th Generation (1992–1996 & 1997–2001) 3 08-01-2006 06:33 PM
1991 Pickup Front Brake Problem HELP?? beanj 89-95 Toyota Pickup/Hilux 4 04-06-2006 11:06 AM
