This may sound odd but maybe it is just that your car doesn't "like" that brand and/or weight of oil. I have noticed this on several of my cars and trucks over the years, you can tell small differences in the car you drive every day for years, after all. Alot of them seemed to run just a little better on one brand than another. alot of people here know exactly what i am talking about - my truck seems to like penzoil, as did most of my other cars, castrol not so much, valvoline none of them seemed to like.
If that sounds weird so be it, alot of the time i just mix brands of oil but usually not oils of different weights just to get clean oil in there (which is more important than what brand you use). Sometimes i will mix in one qt of mobil 1 with 4 of dino (V6) and you can tell the engine is benefitting from it as it runs just a little bit smoother.
I think its safe to say you wont be using this brand or weight again anytime soon - since you live here maybe you should try 5-30 or even 15-40 if you want to use Mobil 1.
