Hmmm, What year is your car? Perhaps they share the same ground. Have you done anykind of modding to your lights?
__________________ Your source for Gen6 TSX Retro's (PM for details)
2005 Lexus ES330
2007 Camry SE V-6 Titanium(SOLD)
Moonroof, Navi, Sport Leather, Floor Mats, Phillips 4300k HID, 15% Tint, Silverstar Turn signals “My friends call me ‘The Cane.’ Even before I messed up my leg.” ~Dr. Gregory house
I Think We Need To Put Up A Statement Telling People To Include Common Sense Information About Their Vehicles(i.e. Vehicle Type, Generation, Mileage, Trim Level[If Applicable], And Engine Size) You Know?
Assuming you have a GEN5 from previous posts from you. The High and Low beam DO share a ground. Nor do they share a fuse. How do you know the bulbs are good? Have you switched them with the passenger side?
2005 Lexus ES330
Assuming you have a GEN5 from previous posts from you. The High and Low beam DO NOT share a ground, So thats out of the question. Nor do they share a fuse. How do you know the bulbs are good? Have you switched them with the passenger side?
Yep, switch over the bulbs to see if the bulbs are bad... check the connectors to make sure they're not fried... and check the wires to make sure there's no discontinuities
bad relay?
check bulbs with pass side?
bad connectors?
bad harness?
the headlights on a gen 5 have a pigtail harness going to each set of headlights, and you could have some sort of disconnect with that or there could be an issue with the harness itself or the connectors for the high/low beams (doubtful since there are different connectors)
wtf does any of that have to do with a headlight other than the gen?
anyways, 03 no modding. If it were the connectors or the harness it wouldn't make sense that both hi & low went out at the same time. The relay seems to be the most likely thing. i'll give that a try and if it doesn't work i guess its off to the garage.
wtf(IS THIS CALLED FOR?) does any of that have to do with a headlight other than the gen?
You Do Know Other People Have Questions About Their Car. Other Than A Damn Headlight. Don't Take Your Frustrations Out On Me. I Was Just Making A Suggestion To TN, Because I Noticed One Of The Mods Replied To Your Post.
When Semi-New Comers/New Comers Post Questions About Their Car, Some Don't Post Enough Information. And Those We Some Of The Questions Fellow TN Members Have.
2005 Lexus ES330
cool man. i dont disagree with your statement i just think you could have picked a better and more relevant thread to say it in. take it easy brother. happy holidays
ok, I lied, they DO share a ground. Check the ground wire on the left fender. Should be attached to the left inner apron assembly.
The ground is (EC)
2005 Lexus ES330
there is one large relay fuse labelled "HEAD" and then two fuses for rh upper and lower and lh upper and lower. Do you know that the big "HEAD" relay is for?
