Finally got to fix the window after a very thorough google search. Gen 5 service manual states nothing. Taken from another forum. I'll post it here FYI. There is no reset cycle of window down, up, power on, off, etc. You actually have to disassemble the motor from the regulator.
1)Remove glass
2)Remove regulator and motor assembly
3)Remove motor from regulator
4)Attach motor to electric connector
5)Turn key to accessory on position
6)Use power down window switch and engage auto down till motor stops
7)Mark one of the gears
8)Use master window switch and push button up in baby steps. Watch the gear make at least 6 revolutions but no more than 10.
9)Remove motor electric connection
10)Reassemble everything together & smile you got your window fixed.
By the way, my front passengers window stopped working at this time too.
You could hear the click of the window switch but nothing with the motor. I took apart the window, gave a solid strike with a hammer to the motor and voila... works. My rear left passengers window had the same symptoms a while ago so luckily this was an easy fix. Maybe this will teach us to at to bring down all windows at least once a week or so so the motor doesn't get frozen.
