06 SE 3.3 trans fluid - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-01-2008, 12:03 PM   #1 (permalink)
View Jeremy_B's Photo Gallery
Gen5 06 SE 3.3 trans fluid
Hey guys, quick question. I recently bought the car from a dealer w/28k miles on it, I'm around 37k now. I went in for an oil change and the guy smelled the trans dip stick and said do you drive fast? He went on to say it smelled a little burnt, I figure I should get it out of there soon and put some new stuff in. Should I go to the dealer or to a regular lube place?
Jeremy_B is offline   Reply With Quote
Old 01-01-2008, 12:19 PM   #2 (permalink)
480 HP 2.4L = lying ricer
TRD VVTi's Avatar
View TRD VVTi's Photo Gallery
Gen5
I doubt that a regular lube place would have the correct Toyota Type T-IV fluid.
2006 Camry LE Special Edition
Old 01-01-2008, 12:26 PM   #3 (permalink)
Yeah that would definitly be a big concern them throwing in the wrong stuff.
Do you send your camry to the dealer and if so do they give you a loaner or do work on the wknds? I am not going to be able to take any days off from work until july.
Old 01-01-2008, 12:31 PM   #4 (permalink)
TRD VVTi's Avatar
Gen5
You will have to check with your specific dealer.
You should be able to wait for it, as long as you make an appointment.
Address any time concerns that you have when you schedule, and again when you arrive to be checked in.
Transmission Problems wareagle2000 2nd Generation (2005+) 21 07-23-2007 09:11 PM
2005 Camry Automatic Trans Fluid Change Interval lucian688 5th & 6th Generation (2002-2006 & 2007-2011) 16 04-01-2007 10:12 AM
??'s about the nver needs changing AT fluid kn38ms 2nd Generation (2005+) 22 10-29-2006 07:42 PM
