05 Camry Mushy Soft Brakes - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-01-2008, 03:01 PM   #1 (permalink)
View wiseowl's Photo Gallery
I just bought a 2005 Camry XLE, V-6. Everything works fine except the brake pedal has a long travel ( about 2 inches) before the breaks bite in. The pads are a bit worn, about 1/8" of thickness left. The rotors look fine, some monor scratches but no pulsating. Brake fluid is OK in reservoir.
Is this brake mushy normal? Any thoughts or experiences??????
Thanks,
Wisowl
wiseowl is offline   Reply With Quote
Old 01-01-2008, 03:56 PM   #2 (permalink)
480 HP 2.4L = lying ricer
TRD VVTi's Avatar
View TRD VVTi's Photo Gallery
It sounds completely normal. It's a common complaint that the brakes feel soft even though they work normally.
2006 Camry LE Special Edition
Old 01-01-2008, 04:07 PM   #3 (permalink)
The Biggest comment Whore
Avalonman's Avatar
View Avalonman's Photo Gallery
this is normal
Avalonman is offline   Reply With Quote
Old 01-01-2008, 06:01 PM   #4 (permalink)
The Connoisseur
CharmCityES's Avatar
very normal....gen 5 camrys commonly are faulted for brake pedal travel and spongy brakes....its just how the car's brakes are
The "Executive Sedan"
Old 01-01-2008, 06:31 PM   #5 (permalink)
Thanks everyone!
I appreciate your comments
Wiseowl
Old 01-02-2008, 12:42 AM   #6 (permalink)
View TRDGen5.5camry's Photo Gallery
agree that why i am thinking of getting some steel brake lines from stoptech. Maybe that will not feel that soft when braking
TRDGen5.5camry is offline   Reply With Quote
Old 01-02-2008, 01:07 AM   #7 (permalink)
BANNED
View w203's Photo Gallery
it will help somewhat but the braking system is designed with lots of brake play. upgrading to new pads would also help as with higher piston calipers
w203 is offline   Reply With Quote
Old 01-02-2008, 06:13 AM   #8 (permalink)
2AZ-FE
jimmy-j's Avatar
View jimmy-j's Photo Gallery
alot of people fail to upgrade their bmc's after upgrading their calipers to dual or quad piston calipers.
if you go the route of upgrading your calipers for more pistons don't forget to upgrade the bmc.
correct me if i'm wrong but doesn't the xle also have rear drums? i'm not sure how much that comes into play since it is the rear brake but keep that in mind as well.
2004 Camry SE -- 2AZ-FE -- 5.speed
jimmy-j is offline   Reply With Quote
Old 01-02-2008, 03:50 PM   #9 (permalink)
Avalonman's Avatar
Only Certain XLE Models Have Rear Disc Brakes. All V6 Models Have Rear Brakes. Certain SE/XLE Models That Have Alloy Rims From The Factory Have Rear Disc Brakes. Other Than That, They All Have Rear Drums.
Old 01-02-2008, 04:41 PM   #10 (permalink)
BANNED
avalonman basically said what i was going to say and more about the xle rear drums. as for the camry's bmc, the duals like the ones from the is300 could be retrofitted without an upgrade but anything more would need one. this applies for the 5/6th gen camry though, different for other applications
Old 01-02-2008, 06:39 PM   #11 (permalink)
Thanks everyone for the replys. I have rear disc brakes. It sounds like the caliper retreats back to a certain dstance after each time the brake is applied. Therefore the caliper has a longer travel distance as the brakes get worn. I will start with new pads and bleed the brake lines.
Thanks everyone!
Overall Comparison: Toyota Camry XLE V6 v.s. Pontiac Grand P CamryLeb Camry & Solara Lounge 25 08-13-2007 10:55 PM
Official 2007 Toyota Camry Announcement, Images & Specs EKam Toyota News 1481 05-17-2007 09:50 PM
Soft Brakes Gil Chesterton Camry & Solara Lounge 14 03-28-2006 11:03 AM
Foglights for Camry 05 LE? HELP!!! Appleseeds 5th & 6th Generation (2002-2006 & 2007-2011) 20 04-21-2005 09:12 AM
Good Bye 01 Camry, Hello 05 Corolla caspah Archived Corolla threads 2 12-12-2004 11:33 PM
