Using Gasoline with a 91 Octane level - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-01-2008, 05:57 PM   #1 (permalink)
View nick rusche's Photo Gallery
Gen5 Using Gasoline with a 91 Octane level
I was just wondering if anyone out there uses gasoline with a 91 octane level in their 4 cylinder Gen 5 Camry. Do you notice any difference in the car's performance, and does it hurt the car at all?
Thanks!
nick rusche is offline   Reply With Quote
Old 01-01-2008, 06:07 PM   #2 (permalink)
Gameroom cash: $203160
View CamrySExxx's Photo Gallery
Thanks!
why not get the recommended octane? You know what would be pretty much the same as putting 91 in your gas tank? putting 89 and giving me the difference in money
CamrySExxx is offline   Reply With Quote
Old 01-01-2008, 06:46 PM   #3 (permalink)
The Connoisseur
CharmCityES's Avatar
it does absolutly nothing
the car is rated to run on regular 87-89 octane gasoline...
why spend the extra money when it adds nothing in performance or benefits to the engine?
id tell you too run 92 if you had a V6 engine, as toyota reccomends premium for the 3.0 and 3.3 V6 engines for "optimum performance", but it isnt required.
The "Executive Sedan"
Old 01-01-2008, 07:19 PM   #4 (permalink)
HID/Retrofit Expert
white3ch0c0late's Avatar
iTrader Score: 7 reviews
View white3ch0c0late's Photo Gallery
Save your money.
2009 Audi TT 2.0T --- THE BEAST!
2002 LE 4Cyl --- Gone, but not forgotten. 06/28/09
Glaring blue HID bulbs are NOT classy, and don't make your car look nice, no matter what that kid in the Civic told you.
white3ch0c0late is offline   Reply With Quote
Old 01-02-2008, 10:43 AM   #5 (permalink)
480 HP 2.4L = lying ricer
TRD VVTi's Avatar
View TRD VVTi's Photo Gallery
The only thing that you will gain is extra deposits in the combustion chamber from the slower burn rate of the higher octane fuel under normal conditions.
2006 Camry LE Special Edition
Old 01-02-2008, 12:21 PM   #6 (permalink)
JAKSTER's Avatar
View JAKSTER's Photo Gallery
Gen6
WHAT IF I PREFER TO USE GASOLINE WITH HIGHER OCTANE RATINGS? You can, but there are no real benefits, other than the gasoline manufacturers making more money off of you. When you use a fuel with a higher octane rating than your vehicle requires, you can send this unburned fuel into the emissions system. It can also collect in the catalytic converter. When you over stress any system, it can malfunction or not do what it was designed to do properly. In the early 90's, an early warning symptom was a rotten egg smell from the tailpipe. Easy fix, go back to using regular 87 octane gasoline. The rude odor usually disappears after several tanks of gasoline.
DOESN'T HIGHER OCTANE GASOLINE HAVE MORE CLEANING ADDITIVES THAT ARE GOOD FOR MY ENGINE?
No. Government regulations require that all gasoline contain basically the same amount of additives to clean the injectors and valves. The only differences are the type to help create the different octane ratings. All gasoline burns at the same rate, it is the additives that create the different octane ratings for the different types of engines.
REFORMULATED GASOLINE
In some major cities with air pollution problems, reformulated gasoline is required. It is an oxygenated fuel, that burns really clean but can slightly lower fuel economy and engine performance. If your engine is really dirty with carbon deposits, it will also cause pinging or premature burn. In these types of situations, you may want to consider stepping up to the next grade of gasoline.
The bottom line is to use the type of gasoline recommended for your engine. In some cases, like towing, or other stresses on the engine, you may find a higher octane fuel helpful.
NOTE: I do not proclaim to be an expert in these matters, but am only presenting an overview of what I have discovered in my work in this industry with the different auto manufacturers.
TUNER OR LATER
JAKSTER is offline   Reply With Quote
Old 01-07-2008, 04:04 PM   #7 (permalink)
View giga_dude's Photo Gallery
So what you are saying is by fueling higher octane gas it might damage the car?? I am wondering about this because I might move to Germany in July and I will take my Camry with me...but there they only have 95 and 98 octane gas.....
giga_dude is offline   Reply With Quote
Old 01-08-2008, 12:49 PM   #8 (permalink)
Asian N00b Modder
Gellenole's Avatar
View Gellenole's Photo Gallery
I think i'm going to go 89 on my next fill up on my v6 and see what happens.
1995 Camry I4 @ 123k Miles - RIP 5-26-07
[Silverado Backed into it]
Originally Posted by catric69 View Post
It's cheaper if you get a new gf.
Gellenole is offline   Reply With Quote
Old 01-08-2008, 01:53 PM   #9 (permalink)
Gameroom cash: $303755
JAKSTER,
I just read your reply to this thread. This was an excellent and well written response. Well done.
Mike
Old 01-08-2008, 02:08 PM   #10 (permalink)
Well I read the Toyota Camry Service manual cover to cover when they discuss gasoline and they only state to "use at least 89 octane or higher." If you use lower octane gas it might damage your engine etc etc....
So I can only hope that when I drive my 4-cyl Camry in Germany that the 95/98 octane gas wont damage the engine....
Old 01-09-2008, 11:09 AM   #11 (permalink)
TRD VVTi's Avatar
Do they calculate octane the same way that it's calculated in the U.S.?
Old 01-09-2008, 11:25 AM   #12 (permalink)
College owns my wallet...
Venom_5's Avatar
View Venom_5's Photo Gallery
Jakster - font = too big
giga_dude - are you sure about that?
Buy My Weapon-R Intake [Here]
http://sck388.mybrute.com
Old 01-09-2008, 01:17 PM   #13 (permalink)
View Himes's Photo Gallery
Higher octane ratings ==> more complete engine combustion.
Harmless if your car gas using higher octane ratings gas. As long as your car using the minimum required rating from your manufacturer.
Only one benefit FOR SURE from using higher octane rating gas is safe the environment. Complete combustion will decreased the amount of carbon monoxide and Nox from your engine.
Hope that help !!!
Himes is offline   Reply With Quote
Old 01-09-2008, 01:59 PM   #14 (permalink)
geoff5093's Avatar
View geoff5093's Photo Gallery
Hope that help !!!
I've heard both sides, that using a higher octane gas then whats required will burn better, and I've heard it doesn't burn as clean. I really don't know what to believe, but I see no reason to use whats higher then required.
BTW, the Camry can run on regular unleaded gasoline, it doesn't need 89 or higher.
geoff5093 is offline   Reply With Quote
Old 01-09-2008, 02:50 PM   #15 (permalink)
Gen6
My explaination was based on the emission test that I did in school on a toyota engine tested with different octane number gasoline. The result proved that higher octane number results in better emission rate. But, I dont think people concerns about what out from their car as long as it pass the smog test . The air intake also critical point for your car. If you have a better air intake manifold and air filter in your car, you might notice the differences in mpg with different octane number gas. Anyway, it still depends on the behavior of how you drive your car.
Swapping distributors 3.0 from a 91' to a 93' hairbear65 89-95 Toyota Pickup/Hilux 4 10-24-2007 10:18 PM
FS: 91 5sfe parts (cheap) mr2trd91 Car Parts for Sale 2 09-04-2007 01:52 AM
05 xrs octane rating Corollaxrs05 Archived Corolla threads 0 02-10-2006 11:31 AM
Premium or Regular? wesscamrywagon Camry & Solara Lounge 19 01-10-2006 11:19 AM
home grown octane booster? Yodapower69 Hardcore Tech and Competition 0 09-17-2002 10:38 PM
