2008 4cyl SE MT Performance???? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-01-2008, 07:59 PM   #1 (permalink)
View DanPorges's Photo Gallery
Hi Everyone, new to the forum!!
I just traded my 2006 tC s/c for a 2008 Camry SE. I needed to move up to a 4 door for work, but wanted to stay with a manual transmission so the v6 was out of the question. I would like to get an idea of what performance upgrades are worthwhile?? I saw the K&N Typhoon is available and good for about 14hp, supposedly according the the K&N site. I have also seen some chatter about TRD, Tanabe and HKS exhausts....anything really worthwhile for this setup? Is the TRD clutch from the tC the same part that fits the camry as TRDSparks.com has the same part number listed for both??
DanPorges is offline   Reply With Quote
Old 01-01-2008, 08:25 PM   #2 (permalink)
2008 Camry Hybrid
Yazovets's Avatar
Gameroom cash: $149932
View Yazovets's Photo Gallery
The only way you're going to get a performance boost that you may feel is if you do ECU, exhaust and intake.
Separately, each of these items won't do anything that you will feel.
Loving manual trannies is a personal choice, but you will soon see that the I4 is simply underpowered for this size/weight of car.
2008 Camry Hybrid | Magnetic Grey on Grey Leather | Bi-Xenon H1 4300K Retrofit | Italian Hertz Sound System (dash 4" EM 100, front 6.5" ECX 165, rear 6" x 9" ECX 690, 10" ES 250D sub in custom trunk enclosure, HDP5 5-channel amp, 1320W total power) | 4-sensor Rear Parking System | 20% Metallic Tint | Weathertech Floorliners | 17" ASA AR1 Rims | Toyo Garit KX (winter) | Toyo Versado LX II (summer)
Yazovets is offline   Reply With Quote
Old 01-01-2008, 08:36 PM   #3 (permalink)
Agreed this isnt going to be a drag car, but my tC was only 300lbs lighter with the exact same motor and when it was stock it was still decent. I dont mind the stock performance, just want to get the best I can with whats available...... With the tC, that was a supercharger and exhaust. What can I do to a camry? Does the same S/C fit??
Old 01-01-2008, 09:16 PM   #4 (permalink)
Not-So-New TN User
Netforcer's Avatar
Gameroom cash: $225700
you shoulda took out the supercharger and tried to fit it on the camry... would've been the first
nothing out right now except cai and TRD LSD
My Partial Partout!!!
Photo Album
Old 01-02-2008, 09:20 AM   #5 (permalink)
2AZ-FE
jimmy-j's Avatar
View jimmy-j's Photo Gallery
that's all in personal opinion. i find that the i4 2az-fe gives a good amount of low end torque for city driving and a decent amount of power for passing on the highways. my only gripe is the long throws and notchy feeling of the shifter.
but let's face it. we're talking about a toyota camry. nothing even remotely close to a sports coupe or anything motorsport related.
back on topic -> if anything, an non-tuned intake will only do 2 of 3 things.
better fuel economy + noise
worse fuel economy + noise
noise
2004 Camry SE -- 2AZ-FE -- 5.speed
jimmy-j is offline   Reply With Quote
Old 01-02-2008, 09:49 AM   #6 (permalink)
Gen6
noise
Ok, so with that said, is the K&N Typhoon which is specific to this vehicle and powertrain going to be a Tuned intake?? Should it actually increase both power and MPG while adding a little noise??
Old 01-02-2008, 10:08 AM   #7 (permalink)
2AZ-FE
jimmy-j's Avatar
tuned meaning you'll have to flash your ECU and have it recognize the supposed larger amount of air coming into your intake manifold. what essentially should happen is that the intake should draw in more air and faster and therefore your ECU should spit more fuel to burn since the factory formula has changed and you could potentially be running lean and in turn risk detonation. (it's far fetched and not as extreme but it's along those lines)
after professional tuning of your ECU and timing, your car should - in theory - run more efficiently and yield a hp gain. but keep in mind more air in should also be more air/gas out right? so without upgrading your exhaust side (header, cat, piping and muffler) you'll see virtually no gain (as someone had stated earlier)
2008 Tundra adds 13 new models 91MR2quickNA Toyota News 13 10-16-2007 12:44 PM
The All-New 2008 Toyota Land Cruiser The King Of Off-Road Delivers humanoid Toyota News 0 09-20-2007 11:53 AM
Performance chip for 2004 Camry SE 3.3L V6 5A? wesleyjwilson 5th & 6th Generation (2002-2006 & 2007-2011) 12 01-27-2006 03:40 PM
SE better than LE for my new car...Comments? kthan Camry & Solara Lounge 20 09-06-2005 11:46 AM
Pics of my system install in my 2001 Solara SE 4cyl tmanana Solara 7 09-24-2001 08:59 PM
