Originally Posted by 1BADYOT
I would appreciate ANY advice on what to use on the leather - I really can't afford to re-upholster the entire seat, but I may try to get the piece (inner driver's side by the door) replaced. thanks everyone!
1. First of all, don't do anything to the leather until you get some kind of conclusion with the oil change shop.
2. Check out whatever you may have signed when you got the work done -- you may have signed away your rights "in case of damage." Or, it might outline what they'll do if they damage your car.
3. If you try to get the shop to pay for it, get a quote from your Toyota parts department for the whole "seat cushion cover" -- it should be over $1,000. Plus, get a quote from an upholstery shop to install it -- it should be at least $100. In fact, ask the service writer from your Toyota dealer which upholstery shop they use for warranty repairs -- most dealerships contract out all upholstery work, and whoever they use would be well prepared to take care of your Camry.
4. If you can't get the oil change shop to pay for the problem, your best best is still with that upholstery shop -- I sure do believe that the damaged leather would need to be replaced. BUT, competent upholstery shops "know how to sew" -- they should be able to replace the damaged piece, without the huge expense for the whole seat cover. Probably somewhere around $200 ought to cover it.
In summary:
1. If the shop will cover it, go for the whole OEM seat cover replacement.
2. If it won't, then it hopefully wouldn't be much more than a couple hundred bucks for an upholstery shop to replace the one piece of leather, sew it back together, and put the seat all back together.
3. Good luck!
