Replacing ignition lock cylinder - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-03-2008, 04:26 AM   #1 (permalink)
View KitKat11's Photo Gallery
Question Replacing ignition lock cylinder
Dear All,
Because of
1- There is some one stolen one of the old keys, and using it to open my car.
2- one of the doors look is damaged.
I bought a new ignition lock cylinder kit , i installed doors locks but I faced a problem with ignition switch.
When I installed it, the car goes on (CD lights on for example) but the engine not work..
Now I have two keys, the old key for ignition switch and the new one for doors.
I went to the local Toyota agency to install new ingnition cylinder , but they told me it costs $1000!! , how come this cost while the keys with cylinder costs $130 only.
I HOPE there is away to reprogram the new key or the cylinder to make the engine work,or reprogram the new key to work with old ignition switch.
My car is CAMRY 2004
Please help.
KitKat11 is offline   Reply With Quote
Old 01-03-2008, 10:32 AM   #2 (permalink)
ASE Master Technician
JSM1284's Avatar
Gameroom cash: $186325
View JSM1284's Photo Gallery
Does the car not crank over at all? Or does it crank, yet not start?
Your source for Gen6 TSX Retro's (PM for details)
2005 Lexus ES330
2007 Camry SE V-6 Titanium(SOLD)
Moonroof, Navi, Sport Leather, Floor Mats, Phillips 4300k HID, 15% Tint, Silverstar Turn signals
“My friends call me ‘The Cane.’ Even before I messed up my leg.” ~Dr. Gregory house
JSM1284 is offline   Reply With Quote
Old 01-03-2008, 10:54 AM   #3 (permalink)
Yes, it cranks
Old 01-03-2008, 10:55 AM   #4 (permalink)
JSM1284's Avatar
Hold tight, I'll see if I can pull up the reprogram procedure. 4 or 6 cyl?
2005 Lexus ES330
Old 01-03-2008, 11:08 AM   #5 (permalink)
4 cyl
Old 01-03-2008, 12:16 PM   #6 (permalink)
JSM1284's Avatar
What is your VIN number?
2005 Lexus ES330
Old 01-03-2008, 12:28 PM   #7 (permalink)
Old 01-03-2008, 12:30 PM   #8 (permalink)
JSM1284's Avatar
Originally Posted by KitKat11 View Post
6T1BE33K84X42601
You are missing a digit in there somewhere. Should be 17 digits
2005 Lexus ES330
Old 01-03-2008, 12:33 PM   #9 (permalink)
Old 01-03-2008, 12:42 PM   #10 (permalink)
JSM1284's Avatar
Double check your numbers one more time.
Are you sure its not: 4T1BE33K34X426010
2005 Lexus ES330
Old 01-03-2008, 12:52 PM   #11 (permalink)
i am sure it is
Old 01-03-2008, 12:55 PM   #12 (permalink)
JSM1284's Avatar
The thing is, Toyota has no VINs that start with 6......
2005 Lexus ES330
Old 01-03-2008, 01:02 PM   #13 (permalink)
i know nothing about VIN but when you asked me for it ,, i google and found that 6 means Australia ..[http://www.answers.com/topic/toyota-vin-codes]
Now what to do ,, i have now other VIN
Old 01-03-2008, 01:02 PM   #14 (permalink)
JSM1284's Avatar
Try this:
2. REGISTRATION OF ADDITIONAL KEY
There are 2 ways for registration of additional master key; one way is depressing the brake pedal and acceleration
pedal and the other way is using the hand-held tester.
HINT:
It is possible to register up to 7 master key codes including the already registered key code.
When any operation time described below is over, registration mode will be stopped forcibly.
When the next procedure is started while the timer is working, the timer stops working, then the next
timer starts.
When replacing ”Ignition Cylinder Key Set” or ”Lock Cylinder Set” and register according to the following
procedure using the original master key. However, after the registration of the additional master
key, the original master key and the original sub-key are not necessary any more, and there fore registration
of those key codes should be deleted.
(1) Depressing the brake pedal and acceleration pedal procedure:
Insert the already registered master key in the
key cylinder
Within 15 sec.
Depress and release the acceleration pedal 5
times.
Within 20 sec.
Depress and release the brake pedal 6 times,
and remove the master key.
Within 10 sec.
Insert a key to be registered in key cylinder.
Within 10 sec.
Depress and release the acceleration pedal 1
time. (Security indicator blinks)
After 60 sec. additional master key is registration
is complete. (Security indicator is OFF)
The registration mode is complete when pulling
out the key and depressing and releasing the
brake pedal once or more within 10 secs. after
indicator has been off or 10 sec. have passed.
2005 Lexus ES330
Old 01-03-2008, 01:03 PM   #15 (permalink)
JSM1284's Avatar
I apologize, I didnt realize your location. I assumed you were in the USA. Thats why the VIN you gave me wouldn't come up, I can only access VINs from USA. Try the procedure I posted, Hopefully it works to program the key.
2005 Lexus ES330
Alarm beep/door lock? coolbrze 1st Generation (1995.5–2004) 15 10-08-2007 05:28 PM
Help reprogarming remotes on 2006 Director 2nd Generation (2005+) 10 08-16-2007 02:13 PM
How to remove the valve cover. 2slo5sfe 3rd & 4th Generation (1992–1996 & 1997–2001) 3 08-09-2007 12:26 PM
Getting alarm to chirp procedure - here it is JJMARINE 2nd Generation (2005+) 27 07-13-2007 04:06 PM
Losers in my dealers service department .... lifeisfun 2nd Generation (2005+) 16 04-21-2006 06:45 PM
