2008 Sunroof - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-03-2008, 12:15 PM   #1 (permalink)
machsimus's Avatar
View machsimus's Photo Gallery
2008 Sunroof
I did some searching but couldn't find anything. My girlfriend has a 2008 I4 Camry Sport. She has an awful rattle in the sun roof that is intermittent. She has taken it in and ridden with a technician, but of course it doesn't happen. Has anyone else experienced this? I printed out the TSB from 2007 with the sunroof squeak but I don't think this will help because it is only when the roof is open.
Thanks in advance
machsimus is offline   Reply With Quote
Old 01-03-2008, 12:21 PM   #2 (permalink)
View Sarah7106's Photo Gallery
I just got my '08 SE last night so I've not had my car long enough to note a rattle in the sunroof. In fact it's so cold here (around 16 - 18 degrees) that I've not even opened my sunroof yet. But I will be on the look out for a rattle.
Sarah7106 is offline   Reply With Quote
Old 01-03-2008, 12:25 PM   #3 (permalink)
machsimus's Avatar
She got hers a few months back, and I couldn't get it to happen on the way to the dealership today. Its about 19 degrees here also, so that might have some effect on it.
Old 01-03-2008, 12:48 PM   #4 (permalink)
2007 RED Camry XLE Owner
Old Dood's Avatar
View Old Dood's Photo Gallery
Use a little digital camera and Record (Mini Movie) it when it is doing it.
Burn that to a CD and give that to them....OR..dump to a Flash Drive and upload it to them at the dealer.
"We can't solve problems by using the same kind of thinking we used when we created them." Albert Einstein
Old Dood is offline   Reply With Quote
Old 01-03-2008, 12:53 PM   #5 (permalink)
machsimus's Avatar
Good idea, they said they needed to hear it to get it fixed.
Old 01-03-2008, 02:44 PM   #6 (permalink)
2008 SE V6
thoots's Avatar
View thoots's Photo Gallery
BEAR IN MIND:
Read the TSB very carefully. It doesn't describe the whole process, but refers to it and then goes into the changes required for the TSB....
"The whole process" involves essentially REMOVING YOUR ENTIRE INTERIOR. They've got to take your headliner out to get to the moonroof mechanicals, and they've got to take off all the pillar covers and other pieces to get to the headliner, and they might take out the seats and other trim pieces to get to the pillar covers.
I'll bet you cash money right now: THEY WILL NOT PUT ALL OF THAT BACK TOGETHER AS CAREFULLY AS IT WAS ASSEMBLED IN THE FACTORY.
In fact, you absolutely should consider any "moonroof service work" to quiet any noise up there as "replacing that noise with ten times as many interior noises, which you may never ever manage to quiet, so long as you own the car."
In other words, "DANGER, DANGER, WILL ROBINSON!!"
So, ask yourself the following questions:
How often do you hear it rattle? If it's not that often, can you live with it?
What position does the roof have to be in before you'll notice the rattle? One you would use virtually every time you open the roof, or perhaps one you probably wouldn't use that often at all? If it's not a position you'd normally use, can you live with it?
And so on.
BEWARE.
This sure happened to me with a 2003 Corolla, and the damn rattle only happened when I opened the roof "all the way," which I very rarely ever do. Absolute stupidest thing I ever did in my whole life. I traded that "once in a blue moon" rattle for a headliner that made noise 100% of the time, wherever I went. Absolute stupidest thing I ever did in my whole life.
BEWARE.
thoots
thoots is offline   Reply With Quote
Aftermarket Sunroof Install PLamarine 2nd Generation (2008+) 25 09-05-2011 04:59 PM
LAIAS: 2008 Toyota Sequoia engineer Toyota News 38 11-22-2007 11:21 AM
2008 Tundra adds 13 new models 91MR2quickNA Toyota News 13 10-16-2007 12:44 PM
Sunroof for your Tacoma.. almost zmanphx 2nd Generation (2005+) 15 08-24-2007 03:40 PM
The sunroof pop TSB toyota_tech_01 Scion Forum 4 11-05-2004 01:07 PM
