2002 XLE V6 - Fault Code P0430 Catalyst - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-03-2008, 01:45 PM   #1 (permalink)
View 2002XLE's Photo Gallery
We bought our 2002 Camry XLE V6 new in Jan, 2002. It now has 88,000 + miles. We have ALWAYS burned 92 or 93 octane fuel and have had the car serviced regularly at a Toyota dealer.
Recently the "Check Engine Light" came on and the dealer said it showed Fault Code P0430 "Catalyst System Efficiency Below Threshold Bank 2". The car runs fine and the dealer found no obvious problem, so he turned the light off and said, if it came back on, I would need a $1200 catalytic converter replacement. After about 200 miles, the light came back on.
We planned to trade the car soon and would rather not spend that money, particularly since the car runs fine. We are very disappointed that the cat would fail at 88,000 miles.
Does anyone have experience with this problem? Are there other possible solutions?
Thanks,
David
2002XLE is offline   Reply With Quote
Old 01-03-2008, 01:50 PM   #2 (permalink)
ASE Master Technician
JSM1284's Avatar
Gameroom cash: $186325
View JSM1284's Photo Gallery
Could be a Oxygen sensor being lazy and making the car think the cat is bad. Have the shop perform a pinpoint diagnosis and check the cross-counts on the A/F ratio sensor, And O2 sensor on bank 2. This will tell you if it is in fact a Cat problem, or a sensor saying it is.
Hey, Check out what I just found after writing that^^^
P0430P0430 - Catalyst System Efficiency Below Threshold (BANK2)
CIRCUIT DESCRIPTION
DTC Detecting Condition
The ECM observes the waveform of the heated oxygen sensor located behind the catalyst to determine whether the catalyst performance has deteriorated.
If the catalyst is functioning normally, the waveform of the heated oxygen sensor located behind the catalyst switches back and forth between rich and lean much more slowly.
When the waveform of the heated oxygen sensor located behind the catalyst alternates flutteringly between rich and lean, it indicates that catalyst performance has deteriorated.
CONFIRMATION ENGINE RACING PATTERN
  1. Connect the OBD II scan tool or hand-held tester to the DLC3.
  2. Start engine and warm it up with all the accessories switched OFF until the water temperature is stable.
  3. Race the engine at 2,500 - 3,000 rpm for about 3 mm .
  4. When racing the engine at 3,000 rpm for 2 sec. and 2,000 rpm for 2 sec. alternately, check the waveform of the heated oxygen sensor (bank 1 sensor 2).
Step 1 - 3
Step 4
INSPECTION PROCEDURE
HINT: Read freeze frame data using hand-held tester or OBD II scan tool. Because freeze frame records the engine conditions when the malfunction is detected. When troubleshooting, it is useful for determining whether the vehicle was running or stopped, the engine was warmed up or not, the air-fuel ratio was lean or rich, etc. at the time of the malfunction.
Your source for Gen6 TSX Retro's (PM for details)
2005 Lexus ES330
2007 Camry SE V-6 Titanium(SOLD)
Moonroof, Navi, Sport Leather, Floor Mats, Phillips 4300k HID, 15% Tint, Silverstar Turn signals
“My friends call me ‘The Cane.’ Even before I messed up my leg.” ~Dr. Gregory house
JSM1284 is offline   Reply With Quote
Old 01-03-2008, 02:06 PM   #3 (permalink)
WOW! Excellent info. I'll discuss it with the dealer service guy. Thanks very much, it is good to go in prepared, and you certainly came up with the right stuff.
David
Old 01-03-2008, 02:59 PM   #4 (permalink)
View toyomoho's Photo Gallery
If it is the CAT, shop around for an aftermarket unit at a third party shop to save money.
As JSM states the diagnostics are specific, thus the dealer should be able to find the specific problem.
Old 01-08-2008, 03:57 PM   #5 (permalink)
Well, this is embarrasing - I tightened the the gas filler cap a little more and the light went off and has stayed off. We will get it traded in soon and let the next owner enjoy the fun.
Thanks again to all the great info.
David
Old 01-09-2008, 10:58 AM   #6 (permalink)
480 HP 2.4L = lying ricer
TRD VVTi's Avatar
View TRD VVTi's Photo Gallery
David
The fuel cap tightening had nothing to do with it...
2006 Camry LE Special Edition
Old 01-09-2008, 01:02 PM   #7 (permalink)
Thanks for the comment, can you tell me more? What else might have occurred to shut the light off?
David
Old 01-09-2008, 01:10 PM   #8 (permalink)
The code has nothing to do with the gas tank emissions. If the car had a leaking gas cap another number code would be set.
1st issue with 07'Camry AESANTIAGO 5th & 6th Generation (2002-2006 & 2007-2011) 949 01-08-2008 02:49 PM
so i crunched some numbers, true carlo$ 5th & 6th Generation (2002-2006 & 2007-2011) 36 10-28-2007 06:12 AM
OBD-II Trouble Codes: Full List! thespud Corolla Lounge 0 07-30-2006 10:53 PM
2002 V6 XLE with Navigation Question...CD Changer Macreative 5th & 6th Generation (2002-2006 & 2007-2011) 0 04-12-2003 02:23 PM
Chaning to Synthetic Oil on 2002 Camry XLE V6; Question... Macreative 5th & 6th Generation (2002-2006 & 2007-2011) 8 09-11-2002 06:53 PM
