How to replace power steering pump? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-03-2008, 04:05 PM   #1 (permalink)
View rusysu's Photo Gallery
Hi,
I need to replace Power Steering Pump on 4cyl Camry (2005)
Does anyone have any tutorials, walkthroughs or any helpful info? Links?
thanks a lot.
RusYus
rusysu is offline   Reply With Quote
Old 01-03-2008, 04:22 PM   #2 (permalink)
ASE Master Technician
JSM1284's Avatar
Gameroom cash: $186325
View JSM1284's Photo Gallery
  1. REMOVE FRONT WHEEL RH
  2. DRAIN POWER STEERING FLUID
  3. REMOVE FRONT FENDER LINER RH
  4. REMOVE FRONT FENDER APRON SEAL RH
  5. REMOVE FAN AND GENERATOR V BELT SST 09249-63010
  6. DISCONNECT OIL RESERVOIR TO PUMP HOSE NO.1
    1. Remove the clip and disconnect the oil reservoir to pump hose No.1. NOTICE: Take care not to spill fluid on the V belt.
  1. DISCONNECT PRESSURE FEED TUBE ASSEMBLY
    1. Disconnect the connector from the power steering oil pressure switch.
    2. Using a spanner (27 mm) to hold the pressure port union, remove the union bolt and gasket.
  1. REMOVE VANE PUMP ASSEMBLY
    1. Disconnect the connector from the oil pressure switch.
    1. Using SST and a deep socket (14 mm), loosen the bolt A. SST 09249-63010
    2. Remove the bolt B and vane pump assembly-
Your source for Gen6 TSX Retro's (PM for details)
2005 Lexus ES330
2007 Camry SE V-6 Titanium(SOLD)
Moonroof, Navi, Sport Leather, Floor Mats, Phillips 4300k HID, 15% Tint, Silverstar Turn signals
“My friends call me ‘The Cane.’ Even before I messed up my leg.” ~Dr. Gregory house
JSM1284 is offline   Reply With Quote
Old 01-03-2008, 04:26 PM   #3 (permalink)
That was fast
Thanks a lot!
Thud in the steering wheel and pulls to the left. BlackCamSe 5th & 6th Generation (2002-2006 & 2007-2011) 16 11-25-2007 10:14 PM
HELP: Ratcheting Noise in steering column when turning at low speeds... SIrMack 5th & 6th Generation (2002-2006 & 2007-2011) 29 11-14-2007 12:03 AM
power steering pump beppy General Discussion 7 07-16-2007 01:41 PM
replacing 3VZ-FE power steering pump mazdaverx7 Camry & Solara Lounge 1 09-15-2005 10:33 AM
Power Steering Pump Rebuild 92 P/u 3vze RICHIE Introduce Yourself Here 5 01-28-2005 04:06 PM
