Ice on Inside of windows 07 LE - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-03-2008, 05:44 PM   #1 (permalink)
View RavCam's Photo Gallery
My daughter drives about 2 miles to work. Whenever she gets back into the car, after work, her inside windows are covered in Ice. Before the winter weather came, the inside windows would be fogged up after work.
We keep it in a dry garage, so we know she's not bringing in snow or rain when she gets in.
Has anyone else seen this problem, or what may be causing this?
2007 Rav4 AWD Limited i4, Black
2007 Camry LE i4, Gray
2007 AltimaSL, Black
RavCam is offline   Reply With Quote
Old 01-03-2008, 05:55 PM   #2 (permalink)
ASE Master Technician
JSM1284's Avatar
Gameroom cash: $186325
View JSM1284's Photo Gallery
Warmer air inside the car condensates when it comes into contact with the cold winshield. Basic physics i think.
Try running the car with the A/C or defrost on. Either or will remove moisture from the air inside the car and prevent this occurence.
Also check the Cabin Air Filter, a dirty or clogged cabin filter can cause foggy windows.
Your source for Gen6 TSX Retro's (PM for details)
2005 Lexus ES330
2007 Camry SE V-6 Titanium(SOLD)
Moonroof, Navi, Sport Leather, Floor Mats, Phillips 4300k HID, 15% Tint, Silverstar Turn signals
“My friends call me ‘The Cane.’ Even before I messed up my leg.” ~Dr. Gregory house
JSM1284 is offline   Reply With Quote
Old 01-03-2008, 06:02 PM   #3 (permalink)
She manages to get it cleared out as the car warms. The windows are clear when she gets out, But why is it icy when she gets back to it after it as been parked?
I will check the cabin filter.
Old 01-03-2008, 06:06 PM   #4 (permalink)
JSM1284's Avatar
Another thing, does she normally keep the ac controls on "recirculate" mode? If so, Try changing it to "fresh air" mode before parking the car.
2005 Lexus ES330
Old 01-03-2008, 07:08 PM   #5 (permalink)
The cabin air filter looks new.
She keeps it on defrost, she usually has the air button and defrost both pressed. It looks to me like you can't have the recirculate button on while the defrost button is pressed.
I took it for a 2 mile drive and am going to leave it outside and see if it happens for me.
Old 01-03-2008, 07:53 PM   #6 (permalink)
JSM1284's Avatar
Rather than keeping it on defrost, Once the windows are clear, turn the A/C on in the fresh air mode, but keep the temp dial all the way hot.
2005 Lexus ES330
Old 01-03-2008, 08:59 PM   #7 (permalink)
Thank you both! Great explainations. Makes sense to me.
Hopefully thats it. I am going to leave a note in her car till she gets the habit.
John
Old 01-03-2008, 09:12 PM   #8 (permalink)
BANNED
View w203's Photo Gallery
what are the temperature readings from where you live? its around zero degrees fahrenheit today and there wasn't any ice on the windows. are the window trims in good condition? any cracks or tears? try wiping the windows clear next time and see if it continues to collect ice
w203 is offline   Reply With Quote
Old 01-03-2008, 09:19 PM   #9 (permalink)
View bondbond55's Photo Gallery
I have the same Issue on my XLE. Windows are all fogged up when I come out to my car after work at night. Only had the ice issue happen to me once.
I did have a water leak when I first purchased the car. The factory failed to connect the sunroof drain. I have also seen moisture on the INSIDE of the rear brake lights. Not sure if this is indication that I may have another leak somewhere.
07 XLE V6 Magnetic Grey
bondbond55 is offline   Reply With Quote
Old 01-03-2008, 09:50 PM   #10 (permalink)
View danorthface's Photo Gallery
You can think of the AC as a dehumidifier. I leave it on all the time. You can leave the temperature dial at the midway mark unless you like it really hot.
This is what I learned in high school chemistry. Hot air holds more water than cool air. When you're in the car with the heater on, your breathing will leave moisture in the air. When you park the car outside, as the windows cool, the moisture will condense on the windows. If it's cold enough, the condense water will turn to ice.
danorthface is offline   Reply With Quote
Old 01-03-2008, 10:32 PM   #11 (permalink)
Will the car burn more gas with the AC always on?
my very first thread: how to add lights to vanity mirrors on visors for '07 LE? germandebbie 5th & 6th Generation (2002-2006 & 2007-2011) 3 07-02-2007 08:04 AM
does the single-CD/radio of 07 LE have radio mute?(for adding Motorola BT phone kit) germandebbie 5th & 6th Generation (2002-2006 & 2007-2011) 0 07-02-2007 06:53 AM
Inside Windows Fogging Up When Car Is Not In Use bondbond55 5th & 6th Generation (2002-2006 & 2007-2011) 7 01-13-2007 09:14 AM
2005 Windows always dirty on the inside? Lotust25 2nd Generation (2005+) 13 09-21-2005 09:03 AM
