Light Bulb Help!!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-06-2008, 10:22 PM   #1 (permalink)
View thtran036's Photo Gallery
Light Bulb Help!!!
Hello Guys,
I took out my fog light bulbs and my low beam light bulbs earlier. I want to put them back but forgot which bulbs goes for what part. Both fog and low beam have the same wattage which is 55 W and both are the same size H 11. The only difference is the color of the label. One is blue and the other is green.
I thought there wouldn't be any difference so I installed them back yesterday and went on my trip. Night driving seem to be darker, and the roads are harder to see. I don't know if there are any differences in the bulbs even though they're the same wattage. When I looked at the bulbs. The ones with the Blue label looks bigger and more round.
Now I am totally lost. Can any of you tell me which color label goes where, or hints to install the right bulbs to the right places?
Thanks!!!
thtran036 is offline   Reply With Quote
Old 01-06-2008, 10:31 PM   #2 (permalink)
It's Soo Hoo like Yoo Hoo
MrSo0h0o's Avatar
Gameroom cash: $304005
View MrSo0h0o's Photo Gallery
it shouldnt make a difference. both low beams and fogs use the same bulbs.. if you did switch them, there really shouldnt be a difference as both are most likely used for the same amount of time.. it might just be in your head.
MrSo0h0o is offline   Reply With Quote
Old 01-06-2008, 11:08 PM   #3 (permalink)
Gameroom cash: $203160
View CamrySExxx's Photo Gallery
you couldve cracked teh bulb? Did u touch teh bulb with your fingers? This happened to me before. The oils in my finger cause the bulb to crack which reduced the light output ALOT. You should check if they are cracked or blown. PS. Dont touch the glass part, if you do clean it off with clean paper towel
CamrySExxx is offline   Reply With Quote
Old 01-06-2008, 11:47 PM   #4 (permalink)
ASE Master Technician
JSM1284's Avatar
Gameroom cash: $186325
View JSM1284's Photo Gallery
They are they same, No difference. Its all in your head. And if by label you mean the plastic cover on the back of the bulb, The green one most likely came from your headlight.
Your source for Gen6 TSX Retro's (PM for details)
2005 Lexus ES330
2007 Camry SE V-6 Titanium(SOLD)
Moonroof, Navi, Sport Leather, Floor Mats, Phillips 4300k HID, 15% Tint, Silverstar Turn signals
“My friends call me ‘The Cane.’ Even before I messed up my leg.” ~Dr. Gregory house
JSM1284 is offline   Reply With Quote
Silverstar "Ultra" fredster34 5th & 6th Generation (2002-2006 & 2007-2011) 35 07-22-2007 11:55 AM
fog light - light bulb - need style number johnnyzee 5th & 6th Generation (2002-2006 & 2007-2011) 5 02-07-2007 12:15 AM
1998 Gear Selector light bulb burned out dondondon Archived Corolla threads 2 01-20-2007 01:15 AM
05 corolla tail light bulb oem mismatch-any one else had this issue? ekimwons Archived Corolla threads 3 06-10-2006 08:43 AM
