Air Filter - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-07-2008, 08:57 AM   #1 (permalink)
View camryguru's Photo Gallery
Air Filter
So today i removed my K&N air filter and re-installed the stock filter to see if i would get better gas mileage with it than the K&N. With the K&N i have been getting roughly 380 miles to a tank of gas. 380/16=23.75 my I4 should be doing better than that. So im going to do my own test before i start complaining to the dealer. While i was removing the K&N i happened to look in the top of the air box and saw, what looks to be like another filter. Has anyone else noticed this? What exactly is it? What would be the advantages/disadvantages of removing that?
camryguru is offline   Reply With Quote
Old 01-07-2008, 09:18 AM   #2 (permalink)
Not-So-New TN User
Netforcer's Avatar
Gameroom cash: $225700
Do you drive mostly city? I get around that many miles on 14.5ish gallons... but then I drive highway for the most part... as for the second "filter"... it's an acoustic sound dampener to keep the intake quiet... I had mine removed b4 i went to SRI
My Partial Partout!!!
Photo Album
Old 01-07-2008, 09:26 AM   #3 (permalink)
no. i drive a decent mixture of highway/city. i'll also keep a log of how many miles i drive city and highway in my test. i still have 1/2 tank of gas to burn then i'll fill up and see what happens. The car should adjust back to the stock filter by then.
Old 01-07-2008, 12:18 PM   #4 (permalink)
rommel5u's Avatar
View rommel5u's Photo Gallery
Gen6
i'm averaging 25-25.5 on my se v6 and i have a lead foot. i think your calculating it wrong. try this. fill up your tank full then reset your trip meter to zero. drive as usual then when it's time to fill up again, then fill your tank fulll again. now look at how much gallons you just filled up and divide it by the trip meter reading. that should provide you with a more accurate reading.
SE V6,BLACK BEAUTY,17" OEM CHROME SE RIMS,8000 HID KIT,MOONROOF,CUSTOM INTAKE,ECLIPSE/TOMTOM AVN2210 NAV,COLOR MATCHED BADGING,20% ALL AROUND TINT.PAINTED RED BRAKE CALIPER,TRUNK MATS,REAR BUMPER APPLIQUE,REAR SPOILER,SIDE MOULDING,OEM REMOTE START & ALARM,TOODLER CAR SEAT(HEHE).
rommel5u is offline   Reply With Quote
Old 01-07-2008, 12:37 PM   #5 (permalink)
480 HP 2.4L = lying ricer
TRD VVTi's Avatar
View TRD VVTi's Photo Gallery
As stated above, first you should check your mileage properly. You can't do an experiment with inaccurate information and expect to get an accurate result.
I'm sure that you'll find there really isn't any difference between your factory filter and the K&N. I doubt there is anything wrong with your car. If there was, your MIL would be on.
More than likely it's your driving conditions and driving habits that are responsible for your fuel mileage.
2006 Camry LE Special Edition
Old 01-07-2008, 01:33 PM   #6 (permalink)
Not-So-New TN User
Netforcer's Avatar
No... i think what he mean was that he's currently doing his experiment and he still have a 1/2 left to go before he needs to fill up
Photo Album
Old 01-07-2008, 08:55 PM   #7 (permalink)
i did fill up and i did reset the trip, and i always seem to get 380ish miles when the gas light is on and the needle is at or below E. i dont think i drive it hard, just normal. gear changing at 3k or below normally. auto tranny.
Old 01-07-2008, 09:52 PM   #8 (permalink)
View danorthface's Photo Gallery
just to compare, my gear changes usually at 2.4k..
danorthface is offline   Reply With Quote
Old 01-07-2008, 10:02 PM   #9 (permalink)
'07 XLE
Gameroom cash: $283530
View njerald's Photo Gallery
Gen6
+1......unless or in addition, your tires are underinflated.
Easy to check to eliminate the vehicle...after inflating the tires.
Fill-up, jump on the highway and drive ~3 hours (no stops, no flooring it) at 55-65 mph. Pull off, fill up and you should be 32+ mpg.
Mine with 35 psi tires would be 35+ mpg easily.
Old 01-08-2008, 10:46 PM   #10 (permalink)
ok, i check again and my gear shifts at 2k or 2.4k max when I drive.. I think you're driving a bit harder
Old 01-09-2008, 11:32 AM   #11 (permalink)
you've got to be driving the V6 then. i tried this today and my 0-60mph time was around 10 minutes. lol
Old 01-09-2008, 12:19 PM   #12 (permalink)
View slick07LE's Photo Gallery
Speaking of air filters, what is the part number of the TRD filter that can be used for the 07 Camry? Some sites only show a filter for up to an 06 model, while others show a filter that will work in an 07 as well.
slick07LE is offline   Reply With Quote
Old 01-09-2008, 02:02 PM   #13 (permalink)
geoff5093's Avatar
View geoff5093's Photo Gallery
Are you looking for the filter for the I4 or V6?
geoff5093 is offline   Reply With Quote
Old 01-09-2008, 03:45 PM   #14 (permalink)
I4
Old 01-09-2008, 04:34 PM   #15 (permalink)
steveyhustle's Avatar
View steveyhustle's Photo Gallery
i get 380miles on a fulltank on my gen5 and im on 20s lol.. i drive a 4cyl to
Catch me in ya city,
Sittin Pretty,
You know im shinin' dog!
steveyhustle is offline   Reply With Quote
Replacing Engine Air Filter - 2006 Tacoma Scott Oakley 2nd Generation (2005+) 37 11-17-2007 05:45 PM
Borla air filter BUGEATER 2nd Generation (2005+) 7 07-22-2006 08:04 PM
Short air intake question rabinny Archived Corolla threads 55 11-25-2005 08:01 PM
hi-flow air filter venturi soccerman58 Tercel, Paseo, Starlet, and Sera Forum 2 10-22-2005 02:13 PM
Open air filter or panel air filter?? Della D. Turbo MR2 Forum 7 10-18-2004 06:04 PM
