Help wit tires for 20 inch wheels - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-09-2008, 01:19 AM   #1 (permalink)
cptdar.se07's Avatar
View cptdar.se07's Photo Gallery
Gen6 Help wit tires for 20 inch wheels
Out of the following tires, which ones would you recommend for 20 inch wheels? Give me your first and secomd choice plz! Thanks
KUMHO SPT KU31
Yokohama Tire AVS ES100
NITTO NT-555
Falken Tire AZENIS ST-115
Falken Tire FK-452
TOYO PROXES 4
cptdar.se07 is offline   Reply With Quote
Old 01-09-2008, 01:48 AM   #2 (permalink)
Take it easy... :-)
Tobeit's Avatar
Gameroom cash: $119100
View Tobeit's Photo Gallery
KUMHO SPT KU31
NITTO NT-555
Falken Tire FK-452
TOYO PROXES 4
I can only vote for the Toyo's. I have very satisfying experience with them as low profile tires...but these are only good for summer (no matter what the tire guy tells you). Not much a fan of Falken and Nitto. Kumo gets mixed reviews. Never had these Yokohama's. To your other post on the size: with 20" and TRD springs, I would go with 225/35 - its only 2mm smaller than the stock 215/55 in diameter and will not cause issues together with a 20x8 rim. With 235 you probably have a very tight fit with 235/35 and a too large wheel well gap with 235/30 (beats putting TRD springs on). Also, 235 really look better with a 20x8.5 rim which further makes it an even tighter fit. I have seen members here using all these sizes, just make sure you know what you want ....looks vs comfort vs performance vs daily usability.
"Just for Fun" http://www.cardomain.com/ride/2973919
Tobeit is offline   Reply With Quote
Old 01-09-2008, 09:02 AM   #3 (permalink)
Here and there...
Gameroom cash: $153229
iTrader Score: 6 reviews
View lammydi's Photo Gallery
KUMHO SPT KU31
NITTO NT-555
Falken Tire FK-452
TOYO PROXES 4
You didn't give us your criterias as what important to you. Price or Quality like Road noise, Treadwear. So here is both.
Price:
1. KUMHO SPT KU31
2. NITTO NT-555
Quality:
1. Yokohama Tire
2. NITTO NT-555
My choice for the best Value (Price/Quality) is NITTO NT-555
Old 01-09-2008, 09:07 AM   #4 (permalink)
boo.hoo.hoo.
desentrix's Avatar
View desentrix's Photo Gallery
If you want to read more in-depth.
I believe that Tirerack.com has a comparison available.
2007 Magnetic Gray Camry LE V6:
Lit door sills, F/R cathode, trunk cathode, K&N SRI, IS250 chromes, LED tails/ bulb swaps, Katzkin leather
desentrix is offline   Reply With Quote
Old 01-09-2008, 10:25 AM   #5 (permalink)
Support Authenticity!!!
moky-tron's Avatar
View moky-tron's Photo Gallery
Yokohama ES100 sorta slips on wet weather and roads. Never tried kumho.
I'd go with Falken FK452 or Azenis ST115. Good grip on both wet and dry!
If you were to go with Toyo, I would suggest the TOYO T1R.
moky-tron is offline   Reply With Quote
Old 01-09-2008, 10:29 AM   #6 (permalink)
Here and there...
Hey Moky,
If you like the Falken FK452 next time try the Nitto NT-555. I had them both before I like the Nitto much better (less noise, better grip wet and dry) for just about the same price.
Old 01-09-2008, 10:40 AM   #7 (permalink)
moky-tron's Avatar
Originally Posted by lammydi View Post
Hey Moky,
Sadly, pricing for tires here in Canada is a bit different from down there in US a 19" tire here would cost anywhere from 250-300 before tax, depending on the brand. Not many shops carry Nitto either..
Old 01-09-2008, 10:40 AM   #8 (permalink)
FLIP'N THE G-5 WHIP
RICO8458's Avatar
View RICO8458's Photo Gallery
Gen5
katana 20" rims and Yokohama tires.
Got the 50 on my jock cause my G-5 is so Hot...
2005=5.5 2AZ-FE, 2.4L DOHC 16-Value VVT-i, 4CYL, 160hp
RICO8458 is offline   Reply With Quote
Old 01-09-2008, 01:14 PM   #9 (permalink)
Under Reconstruction
Epsilon's Avatar
View Epsilon's Photo Gallery
Out of those choices, I'll go with Toyo Proxes 4.
Epsilon is offline   Reply With Quote
Old 01-09-2008, 01:15 PM   #10 (permalink)
All of these tires are about $150 per tire...the most expensive set are the Kumho's for like $160.
Check out my ride at http://www.cardomain.com/ride/2978350
Old 01-09-2008, 01:27 PM   #11 (permalink)
Here and there...
Which site do you get your price from because Kumho should be the least expensive over Toyo, Nitto and Falken.
Old 01-09-2008, 01:52 PM   #12 (permalink)
moky-tron's Avatar
judging from the OP's other thread on which wheels to go for, he stated Performance Plus Tire. i checked their site. Pretty good pricing!
1. Toyo Proxes 4
- 245/35/20 $125/tire
- 225/35/20 $130/tire
2. Falken AZENIS ST115
- 245/35/20 $149/tire
3. Falken FK452
4. Yokohama AVS ES100
- 245/35/20 $152/tire
5. Nitto NT555
- 245/35/20 $146/tire
- 225/35/20 $150/tire
6. Kumho SPT ku31
- 245/35/20 $137/tire
- 225/35/20 $172/tire
website did state they were INTERNET PRICES ONLY.
Old 01-09-2008, 03:01 PM   #13 (permalink)
Rapid Roy's Avatar
View Rapid Roy's Photo Gallery
1. Toyo Proxes 4
3. Falken FK452
5. Nitto NT555
6. Kumho SPT ku31
Wow, the price on the Proxes 4's have really dropped. There price for the 245/35/20's was $175 or $180 only 6 months ago
Rapid Roy is offline   Reply With Quote
Old 01-09-2008, 03:22 PM   #14 (permalink)
Epsilon's Avatar
Prolly cuz the increase in popularity of the T1-R.
Old 01-09-2008, 05:06 PM   #15 (permalink)
DA FLO'S RIDICULOUS
View ulikemy430's Photo Gallery
iight
i had the azenis st115's and they were quiet , but the fk452 is the new replacment and toyo proxes 4's are pretty good too about 150 per tire more or less depending where you go
ulikemy430 is offline   Reply With Quote
FS: 205/65/15 Winter Tires with Steel Wheels kingrukus Car Parts for Sale 1 11-18-2007 12:16 PM
NEW lift, tires, wheels!! (PICS) and questions mjonags32 2nd Generation (2005+) 46 04-30-2007 08:48 AM
factory tires and wheels alanlotspeich 1st Generation (1995.5–2004) 2 04-26-2007 12:28 AM
Wheels and Tires trdspeedwayblue 2nd Generation (2005+) 3 10-18-2006 11:15 AM
Selling TRD wheels + tires dELuX-4x4 2nd Generation (2005+) 0 03-02-2006 04:52 PM
