Oil change tips? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-11-2008, 06:49 PM   #1 (permalink)
Forgive meee.
liquidi3ladz's Avatar
View liquidi3ladz's Photo Gallery
Oil change tips?
Everytime I change my oil, I seem to siege my oil filter. Kinda nubish of me. Well I changed my oil again today and behold I couldn't use the filter wrench since it kept slipping. I ended up using channel locks to take off the filter, but it made a mess. (Isnt the first time I've done that) Anyway my last oil change I hand tightened the filter and this time around I did the same, but my question is anyone got suguessions on removing the filter with ease?
2002 Camry LE I4
liquidi3ladz is offline   Reply With Quote
Old 01-11-2008, 06:57 PM   #2 (permalink)
'07 XLE
Gameroom cash: $283530
View njerald's Photo Gallery
Gen6
Siege?
What is your Hand Tightening procedure??
Old 01-11-2008, 07:03 PM   #3 (permalink)
Forgive meee.
I tighten it freehand till it stops, then I use two hands to try to get 1/8 - 1/4 of a turn through.
2002 Camry LE I4
Old 01-11-2008, 07:05 PM   #4 (permalink)
ASE Master Technician
JSM1284's Avatar
Gameroom cash: $172825
View JSM1284's Photo Gallery
Are you applying a bit of oil to the new oil filter gasket before putting it on?
Your source for Gen6 TSX Retro's (PM for details)
2005 Lexus ES330
2007 Camry SE V-6 Titanium(SOLD)
Moonroof, Navi, Sport Leather, Floor Mats, Phillips 4300k HID, 15% Tint, Silverstar Turn signals
“My friends call me ‘The Cane.’ Even before I messed up my leg.” ~Dr. Gregory house
JSM1284 is offline   Reply With Quote
Old 01-11-2008, 07:14 PM   #5 (permalink)
Forgive meee.
Of course. This time around I actually cleaned the area where the gasket touches plate.
2002 Camry LE I4
Old 01-11-2008, 07:18 PM   #6 (permalink)
View hossmaster's Photo Gallery
I poke a couple of holes in the bottom of the oil filter and let it drain in the pan. After that its an almost mess free removal of the filter.
hossmaster is offline   Reply With Quote
Old 01-11-2008, 07:25 PM   #7 (permalink)
Gameroom cash: $201860
View CamrySExxx's Photo Gallery
i know what you mean it ALWAYS happens to me!!! even though i hand tighten it, next oil change its a pain. I think it wouldnt be as bad if oil filter was located in a place where you can get more leverage. Anyways instead of seige? i think u mean seized?
CamrySExxx is offline   Reply With Quote
Old 01-11-2008, 07:31 PM   #8 (permalink)
Forgive meee.
^^ Yep seized.
Hah yeah I get like no leverage at the bottom.
2002 Camry LE I4
Old 01-11-2008, 08:10 PM   #9 (permalink)
Gameroom cash: $255930
View LE05's Photo Gallery
get a better filter wrench! those cheap steel stamped oil filters are pretty bad, they never fit the oem filters quite right and are usually quite thin. dealership should have the correct size one, or you can search for assenmacher tools. they make oemish filter wrenches that fit very nicely.
2005 Camry "LE"
TL HID Retrofit | OEM Fogs | SE Bumper | SE Grill | Factory Spoiler | Kosei K1 TS 18x7.5 | BC Racing Coilovers
TRD [RSB | Strut Tower Brace | Exhaust] || Rear Drum to Disc Swap
LE05 is offline   Reply With Quote
Old 01-12-2008, 05:31 PM   #10 (permalink)
View marc780's Photo Gallery
Maybe you are just tightening them too much to begin with. I have changed thousands of oil filters and rarely/never have i see one leak and i have never seen one vibrate itself off from being installed too loosely (but i guess if you have your filter changed by jiffy lube or similar idiots, absolutely anything is possible - another reason i do all my own oil changes).
After so many filter changes i usually know howto tighten it enough where it is not too loose nor too tight. And next change it comes off with moderate to hard hand twisting. A piece of sandpaper or emery cloth held in your hand against the filter will give you alot more grip.
Old 01-12-2008, 06:14 PM   #11 (permalink)
View coontai's Photo Gallery
+1 on the assenmacher tools. I'll never use a typical oil filter wrench again. the sockets are the way to go
coontai is offline   Reply With Quote
Old 01-14-2008, 05:31 PM   #12 (permalink)
Gameroom cash: $167021
View Dave-o's Photo Gallery
Are those cheap wrenches easy to return back to the store if they don't fit the filter right? I got mine from Pepboys and haven't thought about bringing it back (only 9 bucks).
Dave-o is online now   Reply With Quote
Old 01-14-2008, 08:39 PM   #13 (permalink)
Maven
gdanaher's Avatar
Gameroom cash: $318510
View gdanaher's Photo Gallery
Put the other wrenches in your tool box for future use.
Get a replacement filter for the car, take it in and get the right wrench to fit it. If necessary find one of the hoop clamps that adjust to the diameter and tighten up as you twist.
gdanaher is offline   Reply With Quote
Old 07-11-2008, 08:48 AM   #14 (permalink)
must.resist.modding
bandit's Avatar
Gameroom cash: $436410
iTrader Score: 12 reviews
View bandit's Photo Gallery
Ok, I didnt want to make a new thread so I'll bump this. Are the oil gasket that supposedly goes on the oil pan with the plug necessary? I read the Avalon oil change PDF and looked at the youtube video and didnt see anything in regards to the gasket. I'm going to order filters online and wanted to know if the plug gaskets for the pan is needed. If so, I'll order them at the same time.
CarDomain
Old 07-11-2008, 02:14 PM   #15 (permalink)
View sniper34's Photo Gallery
Change the plug gasket. For the extra .75 cents, it makes no sense not to. Always oil the filter gasket. Tighten it snug, then a little snugger (?). No need to two hand it. I never saw one leak or loosen when tightened snug by hand.
sniper34 is offline   Reply With Quote
Toyota Stand on Synthetic Oil siennavan General Discussion 51 12-09-2007 10:00 AM
My Engine Oil & ATF Change routine modestobulldog Archived Corolla threads 10 01-31-2007 08:29 AM
toyota settles law suit on engine geling/sludge teriboberry 1st Generation (1995-1999) 26 01-14-2007 10:51 AM
30,000miles on single oil change(how to help my car?) Part 2 Rob-D Camry & Solara Lounge 6 10-14-2006 01:26 AM
2001 Sienna went to get an oil change. Oil Plug loose, leak all the oil ...what now? 2k1Sienna 1st Generation (1998-2003) 3 11-29-2005 10:16 AM
