Is premium unleaded gas/petrol recommended for a gen5? - Toyota Nation Forum : Toyota Car and Truck Forums
Closed Thread
Old 10-04-2003, 03:54 AM   #1 (permalink)
View SportivOZ's Photo Gallery
Sorry for being so technically challenged,.....I am using a 98% petrol/gas for my gen5,....is it any better than the standard unleaded (91% or something)?
I just want to know since the price difference is quite big in terms of annual use. Is it just marketing hype? Or does it really make a big difference in the long run.
Any mech techy's here can that can clear this out? Ta!
Substance over form = Camry!!!!
SportivOZ is offline
Old 10-04-2003, 09:15 AM   #2 (permalink)
Prepare tortilla chips.
Daffunda's Avatar
View Daffunda's Photo Gallery
I know that it makes a difference between regular 87 and premium 93. It says so in the manual also. I don't know why you would want to put in even higher grade gas. I can actually feel the difference, so it really works.
Daffunda is offline
Old 10-04-2003, 10:29 AM   #3 (permalink)
'04 Camry XLE V6
Kooter's Avatar
View Kooter's Photo Gallery
I use 89 (research) octane gasoline in my '04 XLE V6. Every once and a while I will use 93 octane.
I used to have a '97 Lexus ES300 as well as a '97 XLE V6 (same engine) and if I used only 87 octane gasoline it would stumble under heavy load. (The knock sensors would detect engine knock and retard the timing as a safeguard, which caused the stumble if too low octane was used.)
If your engine is a 4-cylinder then 87 octane is all you need. Using a higher octane will not enhance performance and may even offer less performance...plus it costs more for the higher octane.
I would use 87 octane in the 4-cylinder engine and 89 octane in the 6-cylinder engine.
Kooter
Kooter is offline
Old 10-04-2003, 02:51 PM   #4 (permalink)
View 1200mk's Photo Gallery
87 for inline 4s, the manual says 87 can be used for the v6s as well but if you want more performance they recommend premium (91)
1200mk is offline
Old 10-05-2003, 07:26 PM   #5 (permalink)
H.I.D. Knut
View thisdj78's Photo Gallery
Originally posted by Kooter
........If your engine is a 4-cylinder then 87 octane is all you need. Using a higher octane will not enhance performance and may even offer less performance...plus it costs more for the higher octane.
Kooter
Really? I have a Gen 4.5, 4 cyl and my manual says to use premium unleaded for optimum performance. So you are saying it will actually decrease performance?
I've been using nothing but premium since the day I got the car
thisdj78 is offline
Old 10-05-2003, 07:36 PM   #6 (permalink)
Un-Official TN dude
View TypeZer0's Photo Gallery
do you kno if the gen 3's would retard the timings if it senses knocking?
TypeZer0 is offline
Old 10-05-2003, 11:16 PM   #7 (permalink)
3s-fte power!
djprefix's Avatar
View djprefix's Photo Gallery
The manual will always say to use premium. An octane rating is just how hard it is to burn, so the higher the octane the less risk of detonation. But you'll make the most power out of the lowest octane you can run. It's easier for you engine to burn and will burn more quickly. I say run 87 unless you're going to be flooring it all the time or something like that. There's really no point in running 93.
3S-FTE: 9.3:1 compression + 5psi = owns you!
djprefix is offline
Old 10-05-2003, 11:42 PM   #8 (permalink)
H.I.D. Knut
Well, I do alot of freeway driving, so I'm always flooring it,
thisdj78 is offline
Old 10-06-2003, 01:03 AM   #9 (permalink)
View kenratboy's Photo Gallery
My cars (see sig) book says anything is fine, but a hi-octane (91 or better) will give you added preformance. I use 87 octane, and want to try some 91 (we don't have much 93 or above in Nevada, or Cali for that matter.)
Will it make a difference?
1997 Camry CE V6 5-speed!
Mods: Whiteline rear sway bar & nice tires.
2009 RAV4 Limited V6 4WD
Mods: nothing you would care about.
kenratboy is offline
Old 10-06-2003, 01:06 AM   #10 (permalink)
93 Z24 and 78 Bronco
Nick's Avatar
View Nick's Photo Gallery
performance, no, but you'll get a bit better gas mileage, especially if you do lots of hwy
-Nick
Nick is offline
Old 10-06-2003, 01:10 AM   #11 (permalink)
Hmmm, me likes this high octane thing I do over 2/3 highway driving. What does it do for highway driving?
Old 10-06-2003, 01:16 AM   #12 (permalink)
Nick's Avatar
give you an extra 30-40 miles per tank
-Nick
Nick is offline
Old 10-06-2003, 01:33 AM   #13 (permalink)
Hmm, that would almost compleatly offset the added cost...
Old 10-06-2003, 02:16 AM   #14 (permalink)
The Oddity
Aussie Ed's Avatar
View Aussie Ed's Photo Gallery
i only use 95+RON pulp in my gen 4.5
its better if you want to keep your injectors clean and if you are going to dyno tune it, you may get a few extra kw after a few mods.
i feel that my car runs better with higher octane fuels.
so yeah, i'd personally recommend using pulp thats 95RON+ in any new car or anything that you are wanting to mod in the future or that has been modified.
TN's Aussie Oddity, now with Evo 9 power??
Aussie Ed is offline
Old 10-06-2003, 04:05 PM   #15 (permalink)
_
View vkeks05's Photo Gallery
What's the technical explanation for this?
vkeks05 is offline
Closed Thread
