Programming problems (phone book) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-15-2008, 10:31 PM   #1 (permalink)
08 Camry XLE
View Chiocciman's Photo Gallery
I have programmed a bunch of phone numbers into the Camry with Nav and I wanted to enter my voicemail number into a speed dial.
I entered the number, 555-123-4567 followed by a (P) pause and the passcode: 5551234567p1234. I even tried the (W) wait. Neither will let the phone get past the telephone number. In the Treo the pause stops things for a few seconds and then sends the passcode. It the Camry program it stops after the number is dialed and never continues.
The manual is horrible! How do I do this????
Thanks
Chuck
Chiocciman is offline   Reply With Quote
Old 01-15-2008, 11:11 PM   #2 (permalink)
Take it easy... :-)
Tobeit's Avatar
Gameroom cash: $119100
View Tobeit's Photo Gallery
Gen6
Chuck
I hope you do not mind that we all now call your voicebox? Hope that is not the real number/passcode! Take care.
PS: Have not tried to do that on my Nav but agree that the manual is pretty much worthless.
"Just for Fun" http://www.cardomain.com/ride/2973919
Tobeit is offline   Reply With Quote
Old 01-15-2008, 11:25 PM   #3 (permalink)
Take it easy... :-)
Tobeit's Avatar
...just looked at the number again, good choice to use a fake :-) When you figure it out, let me know!
Old 01-15-2008, 11:49 PM   #4 (permalink)
08 Camry XLE
Thanks, I will post the solution here... if I ever find it. I know it will do it. The question is how? At least I finally got my Treo to talk to the Camry.
Chuck
Old 01-15-2008, 11:52 PM   #5 (permalink)
Take it easy... :-)
Tobeit's Avatar
Gen6
Chuck
I can't help you right now as I am traveling, but try to use more than one pause ....I got my phones connected pretty easy and also address book transfer worked fine.
Old 01-16-2008, 12:02 AM   #6 (permalink)
kooler than da kool-aid
xfyre's Avatar
View xfyre's Photo Gallery
lol
haha, sorry for spam, but that was a funny blonde moment.
xfyre is offline   Reply With Quote
Old 01-16-2008, 12:21 AM   #7 (permalink)
Take it easy... :-)
Tobeit's Avatar
Gen6
Originally Posted by xfyre View Post
lol
- only if you take it all too serious.
Old 01-16-2008, 09:32 AM   #8 (permalink)
08 Camry XLE
I guess I am a little confused by the response. If one pause stops the passcode from being sent, how will more pases make that better? The pasue is programmed into the Camry, not ther treo. Al we are doing is sending tones from the Camry to the Treo. When I add a pause, everything stops after the phone is dialed (no passcode and no way to make it send them).
Thanks
Chuck
Old 01-16-2008, 09:42 AM   #9 (permalink)
Take it easy... :-)
Tobeit's Avatar
Thanks
Chuck
In many mobile devices pause does not stop the dialing process entirely but only pauses it for a certain amount of time (and sometimes waits for a response signal) before proceeding. As I said, I do not know how the Camry nav is setup to do that.
Old 01-16-2008, 10:32 AM   #10 (permalink)
08 Camry XLE
OK, I see what you are saying. Thanks, good suggestion but.....
4 pauses and still no pass code is sent after a 30 second wait. I am wondering if the function works?
Thanks
Chuck
Old 01-16-2008, 01:51 PM   #11 (permalink)
08 Camry XLE
Is there a number at Toyota I can call for tech support?
Chuck
Old 01-16-2008, 02:00 PM   #12 (permalink)
Posting via Handheld
wireless's Avatar
View wireless's Photo Gallery
It isn't pausing between Treo and Camry, the Camry only passes through the tones of your Treo. It should be the same as dialing with your Treo. Are you sure that your Treo supports this functionality through it's native bluetooth profiles?
This is where you insert your signature
wireless is offline   Reply With Quote
Old 01-16-2008, 10:32 PM   #13 (permalink)
08 Camry XLE
No I am not sure of anything. Palm is my customer so I will try to talk to the Bluetooth engineer. When dialing through the Treo it sends the number and then sends DTMF tones after the pause because the voicemail is now connected and it wants to hear audio. It works just fine. I would expect the Camry to do the same. Once the Treo is connected to voicemail via bluetooth and a pause is initiated, the camry should just send DTMF to the phone via the audio channel and it would work fine. The camry allows me to bring up the DTMF keypad and manually enter the passcode and that puts out audio (DTMF) so why not do the same thing after the connect via the Pause feature. I really don't think this is a bluetooth issue.
Anyway, this is a Toyota forum, not an IEEE discussion. I am a microwave/wireless Engineer and you're not going to convince me that it isn't a simple Toyota fix that should work on any phone. There isn't even a description of the Pause and Wait functions in the manual.
Thanks for the support guys. I guess we will put this to bed and I will enter the pass code manually.
B/R
Chuck
Old 01-16-2008, 10:40 PM   #14 (permalink)
Take it easy... :-)
Tobeit's Avatar
Gen6
Wireless makes a good point that the NAV unit simply forwards the Treo signals. Look at your Treo when the NAV unit dials the number and sends the pause signal...what does the Treo screen say? Does it say it sends the pause signal you would expect? If not, I guess the bluetooth connection does not have that command option. If yes, it really should work assuming it works with your treo...
Old 01-17-2008, 10:16 AM   #15 (permalink)
08 Camry XLE
You guys are correct. I does send the pause signal and the phone pauses, but the rest of the string never gets sent. It could be that the handshake from the Treo never comes back. How about a bluetooth system that is actually consistant from model to model...but that's another discussion.
Thanks guys. I will just dial the passcode.
Chuck
problems Programming key fob to 2002 tundra. rydr1 1st Generation (2000–2006) 0 10-24-2007 11:03 AM
fs: panasonic gd88 cell phone Frank@Element Non-Automotive 0 06-02-2004 01:36 PM
