Car won't turn over. Ignition gone bad or battery? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-16-2008, 12:42 AM   #1 (permalink)
TN の がしょう
xpeed's Avatar
Gameroom cash: $589557
iTrader Score: 7 reviews
View xpeed's Photo Gallery
So, today, my car was running fine until later tonight when I was heading out to the gym. To my surprise, the car won't start. It won't even turnover or let out a little putter. My battery is fine but I think that's where the problem is but then again, I tried jump starting it and it's still no good. I think it's probably a blown fuse or something, but I found nothing so far. Should I take it to the dealers or a toyota mechanic?
1997 カムリ 5-spd *daily driver* Tokico HP - Tein S-Tech - TRD Kit - TRD FSB - ARC - 18" Enkei OR52 - Project Kics R40 - Custom Exhaust - Whiteline 20mm Rear Sway Bar
2003 Infiniti FX35 Sport Package - Metallic Copper
1996 Avalon MCX10 1MZ-FE
http://www.cardomain.com/ride/3900268/1997-toyota-camry
xpeed is online now   Reply With Quote
Old 01-16-2008, 02:15 AM   #2 (permalink)
Here and there...
Gameroom cash: $153229
iTrader Score: 6 reviews
View lammydi's Photo Gallery
This might sound weird but make sure the shift gear is all the way to P.
You you said it won't turn does it give you a noise or everything is just quiet?
Old 01-16-2008, 02:43 AM   #3 (permalink)
Forgive meee.
liquidi3ladz's Avatar
View liquidi3ladz's Photo Gallery
^^ That happened to me once. :P Different car though.
I think you wouldn't be able to pull the key out unless it was in P.
2002 Camry LE I4
liquidi3ladz is offline   Reply With Quote
Old 01-16-2008, 02:48 AM   #4 (permalink)
TN の がしょう
xpeed's Avatar
Not turning, I meant as in the car won't start. Don't worry about it now, I narrowed it down to two things. It's either the battery is dead or the alternator. But I do hope it's just the battery. I tried jump starting the car, it won't start. Called AAA and jump started with their battery and it turned on fine but died again.
Whenever i tried turning the car on, all the lights and headlights would start flaring and blink on and off and eventually die. Then there would be this weird ass humming noise near the fusebox.
Old 01-16-2008, 03:52 AM   #5 (permalink)
Take it easy... :-)
Tobeit's Avatar
Gameroom cash: $119100
View Tobeit's Photo Gallery
That does not sound good and not like that the battery is the original issue (but might be affected as a result though), sounds more like a lot of current goes the wrong way (alternator could be). Humming normally is a sign of an overload, like when their is a short in a generator/compressor or similar. Not much help, but let a professional check that out before you damage more trying.
"Just for Fun" http://www.cardomain.com/ride/2973919
Tobeit is offline   Reply With Quote
Old 01-16-2008, 04:04 AM   #6 (permalink)
View clarkgrizwald's Photo Gallery
sounds like an alternator
clarkgrizwald is offline   Reply With Quote
Old 01-16-2008, 07:03 AM   #7 (permalink)
Maven
gdanaher's Avatar
Gameroom cash: $352460
View gdanaher's Photo Gallery
Make sure the transmission is in neutral or park.
Turn the key and see if the dash lights work. Do they dim out when you attempt to crank the engine?
What's the standing voltage of the battery?
gdanaher is offline   Reply With Quote
Old 01-16-2008, 07:26 AM   #8 (permalink)
View ibgreen's Photo Gallery
FWIW-- It wasn't on my Camry, but my last car, and could still apply. I got it jumped, took it into the place that sold me the battery since it was on warranty. The guy spent all day dorking around, then called me in a panic that "the entire electrical system" was "dead" and needed "redone". Okay, 100,000 plus miles, possible, but..? He calls back 45 minutes later. "Good news- I called the 800 number on the battery and did some tests they told me about- it's a short inside the battery. You can pick it up in an hour."
It shorted overnight?
I don't know if that's of any help, but I wouldn't have thought of it. Then again, unlike this yokel, I haven't spent 20 years as a mechanic.
08 Silver Camry LE V6
ibgreen is offline   Reply With Quote
Old 01-16-2008, 01:24 PM   #9 (permalink)
TN の がしょう
xpeed's Avatar
Oh, of course I'd turn on the car when it's in neutral or park. When I first turned the key, the dashboard and headlights turned on fine, but when I turned it into ignition, everything went crazy and all the lights turned off and started to flicker and eventually the whole car died. But the alarm worked just fine.
A few vip camry pics MattSWE Camry & Solara Lounge 95 07-29-2008 09:43 AM
2005 car battery and/or alarm problem pwmullins 5th & 6th Generation (2002-2006 & 2007-2011) 3 12-16-2007 12:35 PM
My experience w/ a 07 Camry SE I4 auto Linck 5th & 6th Generation (2002-2006 & 2007-2011) 49 08-14-2007 08:05 PM
More on this damn car battery! speedemn Camry & Solara Lounge 14 01-01-2006 09:21 PM
For Sale: 1991 Toyota MR2 non-turbo automatic (many pics) LarryDallas Vehicles 2 07-07-2005 03:15 AM
