timing belt/chains - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-19-2008, 04:55 PM   #1 (permalink)
2002 Camry
ToyotaToday's Avatar
View ToyotaToday's Photo Gallery
timing belt/chains
My 2002 Camry has a timing belt, oppose to a timing chain. Timing chains basically last the life of the car or at least a very long time. My question is... why don't they put timing chains for all cars. Is it because of cost, noisier, etc? Or all the above.
Anyway, what are your thoughts.
My car has his 144,000 km and it's time for a timing belt change. What else should I change/inspect at the same time, besides the water pump.
Thanks
2006 4Runner Limited
ToyotaToday is offline   Reply With Quote
Old 02-09-2008, 09:56 PM   #2 (permalink)
View success's Photo Gallery
are u sure that ur car comes with a timing belt? what model is your car, 02 camry le?
success is offline   Reply With Quote
Old 02-10-2008, 12:05 AM   #3 (permalink)
self-proclaimed geenyus
jermyjerm's Avatar
View jermyjerm's Photo Gallery
wierd that it doesnt have a chain like every other 02 Camry ever made.
jermyjerm is offline   Reply With Quote
Old 02-10-2008, 12:31 AM   #4 (permalink)
Forgive meee.
liquidi3ladz's Avatar
View liquidi3ladz's Photo Gallery
Cause its a V6.
2002 Camry LE I4
liquidi3ladz is offline   Reply With Quote
Old 02-10-2008, 12:48 AM   #5 (permalink)
touringcamry's Avatar
Gameroom cash: $550825
That only applies to Camry I4.
2007 Camry 2.4L 5M
Old 02-10-2008, 09:06 AM   #6 (permalink)
480 HP 2.4L = lying ricer
TRD VVTi's Avatar
View TRD VVTi's Photo Gallery
Belts require much less power to turn than chains do. They are also extremely quite. I'm sure that noise and efficiency are a couple of factors considered by the manufacturers.
Make sure that you check the front engine seals for any leaking or seapage while the belt is being replaced. Any leaking seals can easily be replaced at that time. If they are leaking and you don't replace them it will damage the new belt.
2006 Camry LE Special Edition
Old 02-10-2008, 08:44 PM   #7 (permalink)
2002 Camry
Thanks for the info TRD VVTi.
Old 02-10-2008, 09:29 PM   #8 (permalink)
The Connoisseur
CharmCityES's Avatar
the chain is less maintenence, so alot of companies are switching over to the timing chains these days
and the 2az has timing chain, but 1mz/3mz still have timing belts
The "Executive Sedan"
Old 02-10-2008, 10:33 PM   #9 (permalink)
B0R1CHA
b0r1cha's Avatar
Gameroom cash: $125535
View b0r1cha's Photo Gallery
o so the v6 have a timing belt? do all toyota i4 have timing chains? or just the camry's
19x8.5 +35 Axis Hiro for sale
b0r1cha is offline   Reply With Quote
Old 02-11-2008, 02:01 AM   #10 (permalink)
Owner of much Obsolete
Jeff Lange's Avatar
Gameroom cash: $412112
View Jeff Lange's Photo Gallery
Timing chains are more reliable and less maintenance, however they are typically noisier and require more energy (albeit very minimally). These are the reasons Toyota went with belts instead of chains starting in the early 80's. Toyota's engines with belts are almost always non-interference, meaning if the belt does break, no harm done. With the advent of much more adjustment and lift to the cams, it means that a lot of Toyota engines are now interference engines and switching to a timing chain only makes sense.
The 4-cylinder in the Camry went timing chain with the release of the 2AZ 2.4L in 2002, the 6-cylinder went timing chain with the release of the 2GR 3.5L in 2007.
Almost all Toyota engines at the end of the 1990's were timing belt (Exceptions include the 1ZZ-FE in the Corolla), at this point however, almost all are timing chain. (Exceptions include the 3MZ-FE in the Solara, and the 2UZ-FE in the Tundra/Sequoia). Pretty much every Toyota engine before 1980 was a timing chain, and most everything from around 1980 - 2000 was timing belt. Now it's back to chains again.
Jeff
2011 Lexus IS250 Obsidian "F-Sport 6MT" with LSD
1986 AE86 Corolla GT-S Supercharged
Jeff Lange is offline   Reply With Quote
Old 02-11-2008, 02:13 AM   #11 (permalink)
The 3MZ is an example of a Toyota engine with a timing belt that has an interference design.
2007 Camry 2.4L 5M
Old 02-11-2008, 11:39 AM   #12 (permalink)
View ChiTDI's Photo Gallery
Thanks
Yeah besides the belt and H20 pump, I'd change the tensioner, accessory belt, cam seals, and maybe the valve cover gasket depending on the age.
ChiTDI is offline   Reply With Quote
Old 02-11-2008, 12:48 PM   #13 (permalink)
B0R1CHA
b0r1cha's Avatar
so our 3.5 are timing chain. correct?
Old 02-11-2008, 12:56 PM   #14 (permalink)
Jeff Lange's Avatar
They are.
Old 02-12-2008, 04:19 PM   #15 (permalink)
View marc780's Photo Gallery
The manufacturers first introduced timing belts on engines in the 1960's, Pontiac made a straight six like this back then - then they started using them in lots of engines but it never has and probably never will replace the timing chain. Having worked on plenty of both kinds of engines, i say that all things considered a timing chain is always superior to a belt. If your engine has a chain and the oil gets changed, chances are you'll never have to give it any attention whatsoever. Despite all the arguments and reasons you hear about timing belt v. timing chain etc. its my belief that the manufacturers use them for one reason only, cost. Listen to a toyota 4 cyl engine with a timing belt run and tell me it is quieter after you listen to the same engine on a different model year with a chain instead.
The reason the manufacturer would choose to use a belt is simple. Suppose you run a car company like Toyota and you sell 500,000 camrys a year (toyota sold over 2 million cars in 1st quarter 2007 alone). Now you have a choice of designing in and installing a timing chain in the engine, and the chain at wholesale (you are buying 500,000 of them remember) costs you maybe $30 or 40...or you can use a timing belt instead that costs you less than half that? What are you going to choose? $20 X 500,000 cars = lots of money = lots more profit - is the answer to the mystery as far as i am concerned.
My Timing belt change (very detailed, pics) Gen 4 JerryGiese 3rd & 4th Generation (1992–1996 & 1997–2001) 166 04-09-2012 10:44 PM
Changing V6 Timing Belt Pics and the $270 Coil Connector marc780 5th & 6th Generation (2002-2006 & 2007-2011) 81 04-09-2012 07:26 AM
04 Celica GTS Timing Turbo2tom Celica Forum 2 12-18-2007 03:03 AM
timing belt died in my '91 Corolla gew88guy 6th Generation (1988-1992) 16 11-30-2007 05:17 PM
Part 2: Advancing cam timing allblackalltrac Hardcore Tech and Competition 0 04-16-2004 05:27 PM
