Wheels turn when trans in N
I had my car on 4 stands yesterday doing an oil change and tire rotation. After I finished everything, I turned the car on to check for leaks from the filter. When I stepped out, I noticed the driver side front wheel was turning forward and went back and shut the car off. I did not check the passenger side front wheel. The rotation stopped as soon as I stopped the car. I verified several times that my car was in neutral when it was running. The car only ran for about 30 seconds like this.
Why does the wheel turn? I thought in neutral, there is no power applied to the wheels.
When in neutral with the front wheels on the ground, the car does not move however.
2007 Camry 2.4L 5M
