2005 Camry Check Engine - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-20-2008, 03:18 PM   #1 (permalink)
View Folken's Photo Gallery
Canada 2005 Camry Check Engine
Hey, my Check Engine light has come on and stays ON.
I have checked the oil and tranny fluids and instrument temp is OK.
Do I just take it to the dealer or is there some other thing to do?
What could be causing the Check Engine light to come on anyhow?
Thanks........................... Folken
Folken is offline   Reply With Quote
Old 01-20-2008, 03:40 PM   #2 (permalink)
씨발
PRINCESS PEACH's Avatar
Gameroom cash: $209800
iTrader Score: 22 reviews
View PRINCESS PEACH's Photo Gallery
maintenance light can be easily turned off (usually oil change place didn't reset it)
engine light... u probably have go to a dealer. its okay, its all covered under warranty.
Do you need car parts?
AdvanceSpeedShop
I Am Parting Out: click!
Questions about your own stupidity?: PM NJERALD
PRINCESS PEACH is offline   Reply With Quote
Old 01-20-2008, 04:00 PM   #3 (permalink)
480 HP 2.4L = lying ricer
TRD VVTi's Avatar
View TRD VVTi's Photo Gallery
Gen5
It could be anything. Warranty coverage will only apply if you're within time and mileage of what's causing the light to come on. If you left your fuel cap loose and caused an EVAP system code it wouldn't be a vehicle defect, thus warranty coverage would not apply even if you within the warranty period.
The only way to find out what the problem is, would be to retrieve the code that's set and perform diagnostic procedures related to that specific code.
2006 Camry LE Special Edition
Old 01-20-2008, 08:26 PM   #4 (permalink)
07 Camry SE V-6 Driver
View milkman58@hawai's Photo Gallery
Did you put gas recently? If so , try taking off your gas cap and put it back on till you go to the first click then you must drive a few miles then it should diappear. Otherwise you have to find the ecm code.
milkman58@hawai is offline   Reply With Quote
Old 01-20-2008, 10:57 PM   #5 (permalink)
View sundarpn's Photo Gallery
Go to autozone & get the codes. its free
sundarpn is offline   Reply With Quote
Old 01-21-2008, 02:12 PM   #6 (permalink)
View aycy's Photo Gallery
Oxygen Sensor
It might be your Oxygen Sensor. Your dealer can tell you by checking the code. I have the same problem and it turned out to be the faulty Oxygen Sensor.
aycy is offline   Reply With Quote
Old 01-21-2008, 02:18 PM   #7 (permalink)
View toyomoho's Photo Gallery
Get any codes read then post back with the code number.
Old 01-21-2008, 05:32 PM   #8 (permalink)
Old 01-21-2008, 05:32 PM   #9 (permalink)
Thanks, i will give this a try; otherwise I will take it to the dealer.......Folken
Old 01-21-2008, 06:26 PM   #10 (permalink)
Old 01-21-2008, 06:28 PM   #11 (permalink)
just an update:...I tried the gas cap idea and it made no difference; so it's off to the dealer tomorrow....btw it's still under warranty......Folken
Old 01-22-2008, 05:02 PM   #12 (permalink)
Well here is the latest from the dealer. It needs a new catalytic converter....
Good thing it's still under warranty. Actually it warranty is for 8 years from new.
.............Thanks Folken
Old 01-22-2008, 05:08 PM   #13 (permalink)
ASE Master Technician
JSM1284's Avatar
Gameroom cash: $186325
View JSM1284's Photo Gallery
Yep. 8yr-80k mile warranty on Cats.
Your source for Gen6 TSX Retro's (PM for details)
2005 Lexus ES330
2007 Camry SE V-6 Titanium(SOLD)
Moonroof, Navi, Sport Leather, Floor Mats, Phillips 4300k HID, 15% Tint, Silverstar Turn signals
“My friends call me ‘The Cane.’ Even before I messed up my leg.” ~Dr. Gregory house
JSM1284 is offline   Reply With Quote
94 Camry Check Engine Light Code: 71 Check EGR Valve laksh99 3rd & 4th Generation (1992–1996 & 1997–2001) 15 10-29-2011 07:52 AM
Should I Skip The Camry Alltogether?!?! hikix 5th & 6th Generation (2002-2006 & 2007-2011) 104 05-29-2008 11:33 PM
20R ENGINE REBUILD FROM HELL! (Part Three) nwdetectorist Pre-88 Toyota Pickup/Hilux 1 08-09-2007 07:30 PM
"A" engine info freakinbox Archived Corolla threads 29 05-10-2006 12:05 AM
