wind noise around drivers door - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-24-2008, 08:48 PM   #1 (permalink)
View glocker's Photo Gallery
I have a 2008 camry le.I notice alot of wind noise around the drivers side door,when I hit a bump I hear a whoosh.I checked the weather stripping around the door and everything looks ok.Does anyone else notice this with their car?Thank you
glocker is offline   Reply With Quote
Old 01-24-2008, 11:00 PM   #2 (permalink)
JAKSTER's Avatar
View JAKSTER's Photo Gallery
Get a good cleaner like Mguires spray detail cleaner. Clean the seals around the doors that sometimes helps by making the seal softer. Look for flat spots on the seal that may be your air leak. Sometimes you will have a noise that comes from the mirrors. Try the seal cleaning that also gives you a hands on inspection of the door seal. When I detail I always do my seals.
TUNER OR LATER
JAKSTER is offline   Reply With Quote
Old 01-24-2008, 11:02 PM   #3 (permalink)
'07 XLE
Gameroom cash: $283530
View njerald's Photo Gallery
Gen6
Just take it back for a door adjustment...
Old 01-25-2008, 12:04 AM   #4 (permalink)
2002 Camry
ToyotaToday's Avatar
View ToyotaToday's Photo Gallery
Yes, i totally agree. It's a new car and you shouldn't have to "fix" the problem. It's under warranty.
2006 4Runner Limited
ToyotaToday is offline   Reply With Quote
Old 01-25-2008, 01:24 AM   #5 (permalink)
Take it easy... :-)
Tobeit's Avatar
Gameroom cash: $119100
View Tobeit's Photo Gallery
You here an "wind whoosh" when running over bumps? If you do not hear anything else...your car is okay . Come on guys, whoosh over a bump?
"Just for Fun" http://www.cardomain.com/ride/2973919
Tobeit is offline   Reply With Quote
Old 01-25-2008, 08:55 PM   #6 (permalink)
The wind whoosh I was referring to when going over bumps isn't heard on the other 3 doors, only on the drivers door.
wind noise Bear95 3rd & 4th Generation (1992–1996 & 1997–2001) 21 02-13-2010 11:51 PM
how to program keyless remote for '07 CE? MaximaPower Archived Corolla threads 5 03-02-2007 07:41 PM
New Door Handle on the Driver's side... JayMax03 3rd & 4th Generation (1992–1996 & 1997–2001) 7 01-29-2007 10:52 AM
Strange noise when closing door with Corolla 2006 CE neeco80 Archived Corolla threads 5 09-27-2006 07:47 AM
Anyone else have wind noise in rear of 05 Access Cab Tacoma? asac1 2nd Generation (2005+) 7 09-28-2005 03:43 PM
