hey guys i was just wondering, has anyone had problems with their headlights fogging up? No completely but just the part where the highbeams and daytime running lights are, mostly corners.
It's due to condensation, could be one of many reasons:
1) Manufacture defect
2) You had a retrofit and didn't seal up well enough (Which is my scenario)
3) You've tried to install HID kit and didn't put on the rubber seals well enough
If not:
1) Bring to dealership with a picture.
2007 Toyota Camry SE 2GR-FE
Retrofit TSX HID Projectors | TRD Lowering Springs | Smoked LED Tails | Custom Apexi WS2 Catback Exhaust | BlueBatMobile Eyelids| UR Front Strut Bar | UR 23mm Rear Sway Bar | K&N Short Ram Intake| Kenwood DNX8120 In-dash | Lexus IS350 18" Wheels | Toyota Japan JDM Vent Visors | IS-F Black Leather Shift Knob
Erock08SE, I'd bring it back to the dealership. They should be able to give you a new one so that you don't need to worry about it. There's probably a bad seal somewhere in the housing (condensation). You have an 08.
My 1 month old 2008 camry has moisture in my both headlights and taillights. The moisture covered 85% of my headlight during extremly cold and humanity weather only. So, I took my car back to dealership about 4 times for investigation. Finally, I have brand new replacements for both headlights and taillights.
In the 2008 owner's manual, it's on page 371. In short:
"Temporary" condensation build-up inside the headlights "does not indicate a malfunction."
So, I suppose something more like "permanent" build-up would be a "problem." Frankly, knowing the kind of heat that especially the high beam bulbs put out, I can't imagine that it would hang on for long, once you turned the lights on.
But, moving forward though this section in the manual, these would be problems:
"Large drops of water have built up on the inside of the lens."
"Water has built up inside the headlight."
Condensation is a pretty common phenomenon -- I've noticed it on my car, especially after washing it in cold weather. I sure haven't seen any kind of "permanent" problem worth worrying about....
Now leaking headlights on the new Camry along with slipping transmissions, dash rattles ,door rattles and hesitation..WTF!!!
You Gen 6 guys need to get together and file a Class Action Lawsuit.
I don't have any of these problems and my 95Camry.
Bear
I have HIDs ( not retero ) and i rarely use my highbeams or daytime running lights. I checked the housing and its loose.
It seems that Toyota has the mind set that " hey, a little tranny slip is OK", " Over look the rattles, it is normal because of the expansion of plastic as the car warms up", now water inside the headlights is OK? If moisture is entering the headlight housing, then dust & dirt is also.
Damn the bean counters at Toyota, Damn them!
Bear
Bear
Relax, junior!!!
Air is inside the housings.
There is water vapor in air (humidity).
Water vapor condenses on cooler surfaces.
and then it goes back to a vapor when the temp. increases.
The housings are not sealed and filled with 0% relative air or dry gas.
You don't seem to "GET IT". I have a 95Camry WITH OUT the problems that the Gen 6 has!!! What a deralict the Gen 6 has become.
Bear
No, you don't get it. You may simply live in a climate where you don't experience much in the way of condensation.
Ever wash your car in near-freezing temperatures? Try that sometime, and see if you don't get a little condensation in your headlights. And then come back and let us know what happened.
