Gen 5 With 60k Miles... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-07-2008, 01:16 PM   #1 (permalink)
FLIP'N THE G-5 WHIP
RICO8458's Avatar
View RICO8458's Photo Gallery
Gen5 Gen 5 With 60k Miles...
2005 Camry with 60,000 miles on her. So far so good. At this point in her life span what would you say is the most important things to look out for?
Pete
Got the 50 on my jock cause my G-5 is so Hot...
2005=5.5 2AZ-FE, 2.4L DOHC 16-Value VVT-i, 4CYL, 160hp
RICO8458 is offline   Reply With Quote
Old 02-07-2008, 01:22 PM   #2 (permalink)
self-proclaimed geenyus
jermyjerm's Avatar
View jermyjerm's Photo Gallery
Gen5
Have the transmission serviced.Check the condition of the blinker fluid.
jermyjerm is offline   Reply With Quote
Old 02-07-2008, 05:46 PM   #3 (permalink)
jermyjerm's Avatar
Old 02-07-2008, 09:20 PM   #4 (permalink)
The Connoisseur
CharmCityES's Avatar
coolant flush if you have a car with RED (02-03)...its not due to 100k if you have PINK (04-06)
trans flush
oil/filter change
check battery
check air filter
clean throttle body
check for leaks
check all hoses and wires etc
car should be running fine if youve done all maintenence
The "Executive Sedan"
Old 02-07-2008, 10:58 PM   #5 (permalink)
The Cool Guy
Super Kaioken's Avatar
View Super Kaioken's Photo Gallery
don't forget the power steering! brake fluid change
-Custom 2.5in Cat-back Exhaust + Borla Muffler + Weapon R Dragon Intake + TRD Rear Sway Bar + TRD Springs + TRD Front Strut Brace
Super Kaioken is offline   Reply With Quote
Old 02-08-2008, 10:07 AM   #6 (permalink)
FLIP'N THE G-5 WHIP
RICO8458's Avatar
You think the power steering fluid and brake fluid needs to be changed at 60K miles?
Old 02-08-2008, 12:46 PM   #7 (permalink)
Glockaholic...
kn38ms's Avatar
View kn38ms's Photo Gallery
Brake fliud should be flushed every 35k to avoid condensation,
once moisture gets in brake fluid it becomes a corrosive.
I always change/ exchange my power steering fluid
with the turkey baster method.. Easy to do.
You can't multiply wealth by dividing it...
kn38ms is offline   Reply With Quote
