02 Valence/under guard removal or replacement? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-13-2008, 07:19 PM   #1 (permalink)
View dunebuggy's Photo Gallery
So I bumped into another car and tweaked my front bumper (boo ). It's not bad, just seems to be a few paint wrinkles and pushed back a bit.
However now I notice the under guard has come loose where it was attached in the center and on the passenger side. I noticed the passenger side screw hole was damaged/enlarged.
Is this piece also called a valence? It is the black plastic guard under the front of the car, attached to the bumper.
So question is: can i remove this without damaging the car? What is it protecting? Any tips or pointers on this one?
Thanks!
dunebuggy is offline   Reply With Quote
Old 02-14-2008, 06:29 AM   #2 (permalink)
480 HP 2.4L = lying ricer
TRD VVTi's Avatar
View TRD VVTi's Photo Gallery
Gen5
Thanks!
It's a splash shield and helps to direct the air. It's only around $25 so just replace it. The dealer will probably have it in stock and know exactly what you are taking about with your description.
2006 Camry LE Special Edition
