Wheel Lugs - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-15-2008, 06:21 PM   #1 (permalink)
View itztrung's Photo Gallery
Gen6 Wheel Lugs
I got some aftermarket wheels for my gen 6 camry and I was wonder what kind of lugs will fit?
itztrung is offline   Reply With Quote
Old 02-15-2008, 06:55 PM   #2 (permalink)
LoudCamry's Avatar
Gameroom cash: $229327
View LoudCamry's Photo Gallery
i believe 12x 1.5 tuner lug
LoudCamry is offline   Reply With Quote
Old 02-15-2008, 09:39 PM   #3 (permalink)
Under Reconstruction
Epsilon's Avatar
View Epsilon's Photo Gallery
^^ Yup. It is indeed 12 x 1.5.
Epsilon is offline   Reply With Quote
Old 02-15-2008, 09:57 PM   #4 (permalink)
480 HP 2.4L = lying ricer
TRD VVTi's Avatar
View TRD VVTi's Photo Gallery
Also, make sure that the shoulder of the lugnuts are the same as the wheel.
2006 Camry LE Special Edition
Old 02-15-2008, 10:08 PM   #5 (permalink)
4u2nv
kasimmmmm's Avatar
View kasimmmmm's Photo Gallery
^Ignore is retarded comment
all tuner lugs have the 45 degrees seats, so don't let him confuse you because he himself is probably very confused. The only time you have to worry about that is if you pick up some old school 2pc wheels which i'm sure you didn't.
Just get 12x1.5 tuner lugs... BTW Rays makes really nice extended lugs.
BTW, which wheels did you pick up?
kasimmmmm is offline   Reply With Quote
Old 02-15-2008, 10:24 PM   #6 (permalink)
TRD VVTi's Avatar
Actually, there are plenty of lugnuts with the above mentioned thread size that will not work with any aftermarket wheels that the OP will probably get. That's exactly why I mentioned it.
Here's an example of 12 X 1.5 (you can see it imprinted on the lugnuts) lugnuts that would probably not work with the wheels the OP will get:
Quit trolling behind every post I make. You don't even know what you're talking about anyways...
Old 02-15-2008, 10:32 PM   #7 (permalink)
4u2nv
kasimmmmm's Avatar
those are ancient!
Those are the old school lugs with the washer ring style seats, which no one uses anymore. There's no wheel manufacturer that makes wheels without the 45 degrees seats.
You learnt something new today. =)
Old 02-15-2008, 10:34 PM   #8 (permalink)
Take it easy... :-)
Tobeit's Avatar
Gameroom cash: $119100
View Tobeit's Photo Gallery
Gen6
I must say I never paid too much attention to those details picking lugnuts , but now I am curious if that is so how we can advice the original OP to pick the right lugnuts for his new wheels? Imagine he wants to order online where the selection is better but he can't test them on the wheels itself - how to find out what fits other 12x 1.5? I often do not see more info on them
"Just for Fun" http://www.cardomain.com/ride/2973919
Tobeit is offline   Reply With Quote
Old 02-15-2008, 10:35 PM   #9 (permalink)
4u2nv
kasimmmmm's Avatar
I highly recommend the Rays extended lugs.. they come in black, blue and red...
Old 02-15-2008, 10:36 PM   #10 (permalink)
TRD VVTi's Avatar
those are ancient!
Actually, they aren't old school. You can pick those exact lugnuts up at your local Toyota dealer because they do come on Toyota and Lexus vehicles. Do some research.
As I stated before, grow up and quit trolling behind my posts. You're gheying up every thread that you do that in.
If you don't know what your talking about, don't just post to argue with me. It's senseless.
Old 02-15-2008, 10:38 PM   #11 (permalink)
TRD VVTi's Avatar
12 X 1.5 refers only to the threads of the lug nut. Not the seat/shoulder.
Most lug nuts have the 60 degree seat/shoulder. Some have the shank like the ones I posted a picture of in the thread above. You can't use the lug nuts with the shank on wheels with the 60 degree seat.
Old 02-15-2008, 10:40 PM   #12 (permalink)
4u2nv
kasimmmmm's Avatar
We're discussing aftermarket wheels, remember? Why are you bringing up OEM wheels? that's a complete different story.
Old 02-15-2008, 10:46 PM   #13 (permalink)
TRD VVTi's Avatar
Because the OP asked this:
So the answer would be the correct threaded lug nut with the correct shoulder. The threads are 12 X 1.5 but the OP did not state if he already had lug nuts or not. Maybe he has lug nuts with the shank but needs the 60 degree lugnuts. Also simply answering 12 X 1.5 will not make him aware that there is a difference. My response was simply additional information to help the OP. Your's was harrassment only. That's what you've been doing all day long.
There is no longer any reason for you to keep screwing up all of these threads. You can stop your trolling anytime. It will help everyone as soon as you stop.
Old 02-15-2008, 10:46 PM   #14 (permalink)
Take it easy... :-)
Tobeit's Avatar
12 X 1.5 refers only to the threads of the lugnut. Not the seat/shoulder.
Most lugnuts have the 45 degree seat/shoulder. Some have the shank like the ones I posted a picture of in the thread above. You can't use the lugnuts with the shank on wheels with the 45 degree seat.
...I do understand that point, but how to order: Most here order aftermarket wheels online and I have never seen a spec about the lugnut requirements on the wheels and often do not see more than thread spec on the lugnut. Online dealers simply ship you fitting lugnuts but if you like to order other, better lugnuts right away....guess the only choice is to look at the wheels first when you got them and order later? Any other choice?
Old 02-15-2008, 10:48 PM   #15 (permalink)
4u2nv
kasimmmmm's Avatar
Tobeit, like I mentioned... there's no reason to worry about the lugs not fitting as long as they are 12x1.5. TRD VVTi is speaking of lugs that no wheel manufacturer uses anymore. Just make sure they are 12x1.5. 12x1.25 is for mitsubishi's and nissans...
EDIT: the website should give a choice between 12x1.5 or 12x1.25 and so on... unless its a manufacturer specific website, for instance, only for Nissans, Mazda's or whatever.
