Originally Posted by DZCamry
No check engine light. We just had the 90K service done in December too.
Welcome to TN.
It's nearly impossible to diagnose a vehicle over the internet. Hell, it can be difficult when you have possession of the car and the right tools.
You'll need to furnish LOTS of specific information:
At what speeds does this happen
On accel, decel, constant speeds, at stops, etc
Does it happen when the engine is hot, cold, both, etc
Does outside/ambient temp affect the problem
How long has it been happening, is it getting worse, better, etc
Does the A/C operation affect the condition
Anything else you could provide would be helpful also.
Are you mechanically inclined? Have you worked on cars before? What is your experience and extent of your knowledge? Could you check the E.G.R. and V.S.V. if needed?
Have you checked the online manual yet?
With the information that you've given, the first thing that I would do is check/clean the MAF and check/clean the EGR valve.
