02 camry electrical problems - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-22-2008, 03:39 AM   #1 (permalink)
View ramelan1's Photo Gallery
ok anyone have this problem. about three months ago the battery light started flashing intermittently. then it starting staying on for some period of time. when i gunned the engine it would go off. well, the battery is new and the alternator tested fine, and the the first dealer i took it to said the alt belt just needed tightening. i got the car from the dealer, and a day later it started doing the same thing. i took it to a second dealer and after a thousand dollers later they said the a wiring harness had to be changed. i took the car from the second dealer, and a day or so later the battery light started flashing again. i took it back and demanded that they find the problem and give me a car to use. this time they said a tsb had been found about the wiring harness for the alternator, and they fixed it without any charge. two days after i got the carback the problem started up again. it seems worse when i start up the car after it has been sitting out over night. the battery light blinds for a few seconds and goes off. it does this intermittently. so far the problem has not run down my battery, but is it very irritating. does anyone haven suggestions????
ramelan1 is offline   Reply With Quote
Old 02-22-2008, 10:02 AM   #2 (permalink)
480 HP 2.4L = lying ricer
TRD VVTi's Avatar
View TRD VVTi's Photo Gallery
Seriously, I started to read your post because I wanted to help you out but it gives me a headache trying to read that clustered up mess.
Edit your thread into sentences and paragraphs if you would really like some assistance. You're making it too inconvenient to help you.
2006 Camry LE Special Edition
