Hey all, I have searched about this and only found threads regarding the a/c light flashing. In which I already had this problem before so I know it't not that. But why won't my green a/c light come on at all anymore? Could it be burnt out? I tried checking to see if I was getting any cold air but its hard to guess. Considering the air outside is still somewhat cold and it could just be that coming through the vents. Maybe, I need my a/c recharged? Anyone have any guesses to why the light doesn't come on? Thanks in advance.
__________________ Your source for Gen6 TSX Retro's (PM for details)
2005 Lexus ES330
2007 Camry SE V-6 Titanium(SOLD)
Moonroof, Navi, Sport Leather, Floor Mats, Phillips 4300k HID, 15% Tint, Silverstar Turn signals “My friends call me ‘The Cane.’ Even before I messed up my leg.” ~Dr. Gregory house
the bulb could simply be burnt out....like stated above check and see iof the compressor comes on...the indicator bulbs do burn out over time, but it doesnt affect performance of the function they control....the bulb is also easy to replace too
Is the green LED for the A/C button easy to replace? Its the one when you push the button in. I thought that one is soldered into place? I hope thats the problem because last time I used my A/C in like September it was working fine.
If it's cold outside you can still test your A/C. Switch to recycled air and turn on the heat until your car is warm. Once your car is nice and warm, turn on your A/C and turn the tempature switch to cool. If your a/c is working, the car should start recycling cold air. This will help you determine whether your a/c is working or not, or is it just a simple light bulb issue
pull out the HVAC controls and do a bulb switcharoo.. takes 2 mins
Your'e misunderstanding which bulb it is. The bulbs that you are talking about are the ones that light up the ring of the controls (red circle in pic) Yes, those are easy to replace but those are working. The one that is not working on mine is the green light when pushing in the A/C button (red arrow in pic) If it is that bulb that is out it seems a lot harder to replace. The bulb is behind the button and looks soldered into place.
the a/c light is led, shouldn't go out that quickly. and yes, its soldered in, and no its not easy to replace. like the others said, check the compressor and make sure your a/c actually works.
for future reference, all the button lights and symbol back lighting (Recirculate, A/C, Defrost) are leds, the outer rings are incandescent bulbs. i've replaced those leds to blue and red, and its not easy. took a little tinkering around to figure out how to get them apart.
if it is indeed the LED thats out, i have a spare gen 5 hvac controls... i'll post up a diy this weekend if you need it.
2005 Camry "LE"
TL HID Retrofit | OEM Fogs | SE Bumper | SE Grill | Factory Spoiler | Kosei K1 TS 18x7.5 | BC Racing Coilovers
TRD [RSB | Strut Tower Brace | Exhaust] || Rear Drum to Disc Swap
Is the compressor underneath the alternator? How exactly do I check to see if it works? Can you distincivley hear it when the engine is running?
Would the light really have anything to do with not coming on if the compressor or another part of a/c system is not working?
