HELP: Are these symptoms of a dead HID ballast? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-25-2008, 08:04 PM   #1 (permalink)
2008 Camry Hybrid
Yazovets's Avatar
Gameroom cash: $149932
View Yazovets's Photo Gallery
Today my left low-beam would no longer fire up. I performed the XenonDepot XtremeHID 4300 kit installation about 9-10 months ago (complete with squirrel spotter mod).
Anyway, over the last week, I had noticed that when I fire up my car, the left headlight ignites with a delay of 1 second as compared to the right one. Also from time to time, the left would not fire up at all. The only solution was to turn the headlights on and off between 1 and 3 times.
Today my left headlight wouldn't turn on for good. I did some simple troubleshooting. I tested the left bulb with the right ballast and it works properly. I tested my right bulb with the left dead ballast and it doesn't work.
Then I put back my right bulb and it works still. I also double checked all connections which were untouched.
So is this basically 99% a dead left ballast since the left bulb works perfectly when paired with the right ballast?
Thanks!
2008 Camry Hybrid | Magnetic Grey on Grey Leather | Bi-Xenon H1 4300K Retrofit | Italian Hertz Sound System (dash 4" EM 100, front 6.5" ECX 165, rear 6" x 9" ECX 690, 10" ES 250D sub in custom trunk enclosure, HDP5 5-channel amp, 1320W total power) | 4-sensor Rear Parking System | 20% Metallic Tint | Weathertech Floorliners | 17" ASA AR1 Rims | Toyo Garit KX (winter) | Toyo Versado LX II (summer)
Yazovets is offline   Reply With Quote
Old 02-25-2008, 08:08 PM   #2 (permalink)
Loving the camry =)
View skyxliner's Photo Gallery
if the bulbs working fine, then it's most likely the ballast. did you install the relay harness or are you connecting to the oem harness. my best guess is perhaps if you can connect halogen lightbulb back to the oem harness and that works. your choices are narrowed down to the ballast.
otherwise if halogen doesn't even work, then maybe the oem harness is bad?
skyxliner is offline   Reply With Quote
Old 02-25-2008, 08:13 PM   #3 (permalink)
2008 Camry Hybrid
Yazovets's Avatar
I use a separate relay harness with fuse for each side. So for sure it's not the OEM harness gone bad. I couldn't try to plug in a standard H11 bulb because I didn't have any with me.
Tomorrow I'm visiting my mechanic to re-balance one of the tires so I'll try then.
Old 02-25-2008, 08:37 PM   #4 (permalink)
Cathode Protector
View cosism's Photo Gallery
I have a set of lvq-212s fs if you need a replacement.
07' SE V6, TSX retro w/ color mod, Chrome 18" GS430 wheels, led bulb swaps, tinted windows, K&N drop-in, Sirius, door moldings(FTMFW!!!!). 2 Britax seats too!
cosism is offline   Reply With Quote
Old 02-25-2008, 09:17 PM   #5 (permalink)
Gameroom cash: $283730
View LE05's Photo Gallery
sounds like the ballast is going... delayed firing or intermittent firing is usually a sign that its the ballast. could possibly be the relay too, but the bulb test is fairly accurate. who knows, try replacing the relay on the driver side, couldn't hurt.
2005 Camry "LE"
TL HID Retrofit | OEM Fogs | SE Bumper | SE Grill | Factory Spoiler | Kosei K1 TS 18x7.5 | BC Racing Coilovers
TRD [RSB | Strut Tower Brace | Exhaust] || Rear Drum to Disc Swap
LE05 is offline   Reply With Quote
Old 02-25-2008, 09:58 PM   #6 (permalink)
2008 Camry Hybrid
Yazovets's Avatar
I don't have additional relay harnesses to replace it with. What would make a ballast go bad? I thought bulbs were the number 1 weak spot? Aren't ballasts supposed to work a longer time?
Old 02-25-2008, 10:37 PM   #7 (permalink)
HID/Retrofit Expert
white3ch0c0late's Avatar
iTrader Score: 7 reviews
View white3ch0c0late's Photo Gallery
Not necessarily.
Ballasts can go bad from poor workmanship, poor installation, improper wiring harnesses, water penetration, etc.
2009 Audi TT 2.0T --- THE BEAST!
2002 LE 4Cyl --- Gone, but not forgotten. 06/28/09
Glaring blue HID bulbs are NOT classy, and don't make your car look nice, no matter what that kid in the Civic told you.
white3ch0c0late is offline   Reply With Quote
Old 02-26-2008, 01:19 AM   #8 (permalink)
View diycamry's Photo Gallery
Does the extra hid bulb heat cause any problems in the 07 projectors?
2007 Toyota Camry SE V6
diycamry is offline   Reply With Quote
Old 02-26-2008, 01:30 AM   #9 (permalink)
HID/Retrofit Expert
HIDs actually create less heat than halogen.
Old 02-26-2008, 07:46 PM   #10 (permalink)
i didn't mean for you to replace the whole harness, just the relay on the harness. sometimes the relay contacts corrode or stick, so replacing the relay may fix the problem.
2005 Camry "LE"
Old 02-26-2008, 09:44 PM   #11 (permalink)
View DiLan's Photo Gallery
One thing to check is if the plug between the stock harness(h11 bulb socket) and the female adaptor on the relay harness are tight together
When I first installed my kit I found that there is some play in between those two, havent got around to it but I'm gonna zip tie them together.
1990 Camry LE V6 25th Anniversary Edition
DONE:Sony Xplod 800W Amp(XM-1252GTR) w/ Dual Kicker Subs, Alpine CDE-102 Deck, New Eliminator Battery, Keyless Entry
TO DO:Intake adapter, fix wheel well rust
*SOLD*2007 Camry I4 SE Alpine White
http://www.cardomain.com/ride/2571595
DiLan is offline   Reply With Quote
Old 02-26-2008, 10:05 PM   #12 (permalink)
2008 Camry Hybrid
Yazovets's Avatar
Alright I was troubleshooting this with my mechanic today. We re-did all connections. We tested bulbs left and right. He also tested for power using some sort of meter thing.
Anyway, out conclusion is that the left ballast is really dead. I've ordered a new one today online and I hope to have this resolved on Friday or something.
I had to go to my mechanic anyway to re-balance my front-left tire. I was getting vibration at highway speeds. The tire has been re-balanced and the vibration went away instantly!
Old 08-21-2009, 03:20 PM   #13 (permalink)
View gus738's Photo Gallery
Why didnt you try to xenondepot for warranty? did they give you the run around or do they step up to their warranty?
i've seen members in the 8th gen civic had problems with xenondepot kit which is why im asking you.
ps i tracked your thread and im aware its old.
gus738 is offline   Reply With Quote
Old 08-21-2009, 08:54 PM   #14 (permalink)
Paul_09WhiteV6
Gameroom cash: $592785
iTrader Score: 10 reviews
View Pawel062's Photo Gallery
yea it was probably the ballast but make sure when you install new one that moisture can't get to the ballasts because even aftermarkets usually last longer. good luck.
WrongFitmentCrew#628
