32,000 miles bought new Nexen tires - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-27-2008, 08:20 AM   #1 (permalink)
Francois L'Ollonais
lollonais's Avatar
View lollonais's Photo Gallery
So, I was hoping that I will not buy tires until the summer, but blew one OE tire that had almost no thread. Since all four were almost bare, I decided to buy all four for $293 mounted and balanced. I decided to get 225/55R16 to replace the michelin 215/60R16. I bought the Nexen N5000. Nice looking tires, nice and quiet. I actually hear the outside air pressure noise more than the road. But my beef is with the mounting. The tires came with those red and yellow dots. Supposedly the yellow is to mount over the valve or use the red to the mark on the rim. I looked and I think they just mounted as they felt like mounting. So I took it back and told them that its vibrating, the guy first tells me that they dont have a high speed balancer, that their equipment is old. Then that its not about the dots, that gets corrected with the weights. Then they try to rebalance. I drive again and not as bad, but still shimmy and vibrations between 60 to 75mph. Are they talking shite?
2007 Black Camry CE
20% Black tints, Prestige Alarm with Solenoid for Trunk
2009 Pearl White Highlander Hybrid Limited
Navigation Package OEM everything except overhead DVD
lollonais is offline   Reply With Quote
Old 02-27-2008, 08:31 AM   #2 (permalink)
Take it easy... :-)
Tobeit's Avatar
Gameroom cash: $119100
View Tobeit's Photo Gallery
If re-balancing does not help (look for a shop with road balancing) you might want to check if the new tires are okay. Sometimes tires are "out of round" and can not be balanced perfectly (they change shape when spun and therefore can not be balanced correctly). In that case, return the tires. I had such a problem just recently and also had vibrations at higher speed only. It just happens, no brand is perfect.
"Just for Fun" http://www.cardomain.com/ride/2973919
Tobeit is offline   Reply With Quote
Old 02-27-2008, 08:42 AM   #3 (permalink)
Not-So-New TN User
Netforcer's Avatar
Gameroom cash: $225700
are the tires directional? if not, then the dots shouldn't matter
My Partial Partout!!!
Photo Album
Old 02-27-2008, 08:43 AM   #4 (permalink)
Francois L'Ollonais
lollonais's Avatar
The only place that does road balancing round heres is the dealer. How much they charge? probably my kidney.
2007 Black Camry CE
Old 02-27-2008, 08:44 AM   #5 (permalink)
Francois L'Ollonais
lollonais's Avatar
Yes they are.
2007 Black Camry CE
Old 02-27-2008, 09:59 AM   #6 (permalink)
480 HP 2.4L = lying ricer
TRD VVTi's Avatar
View TRD VVTi's Photo Gallery
The dots matter, but not very much. I wouldn't worry about it.
Most tire shops and dealers have a balancer that can measure wheel and tire runout, as well as road force variation.
It sounds like a simple rebalance will take care of your vibration from 60-75 MPH.
2006 Camry LE Special Edition
Old 02-27-2008, 11:00 AM   #7 (permalink)
Francois L'Ollonais
lollonais's Avatar
Thanks all.
2007 Black Camry CE
Old 03-05-2008, 08:36 AM   #8 (permalink)
Francois L'Ollonais
lollonais's Avatar
32,000 miles bought new Nexen tires - Update
Its been almost 2 weeks and the vibration is there. I went to Tire Kingdom, where a friend works, last week. He rebalanced them and he told me that they were not properly balanced. So he did and I drove. The vibration was there but not as much. I called him back and told him. He said that he will try to remount them following the dots. I was upset, so I called the shop where I bought them. They checked the rear tires and said that one was "bad", so they gave me a brand new, balanced both rear tires after spining them around the rim with no air to try to match the dots. The guy told me that if that does not fix it, that it could be the drivetrain.
Before you guys lash out on me for buying these tires, I researched and found no bad reviews for them. They actually have 2 corporate buildings here in the states. So what are the chances that all four are bad? My friend at TK will recheck them today, but then I will take it to the dealer to check the drivetrain. Do you guys think that the additional 3lbs per tire will cause this?
I read that other people are having vibration issues, so mine could be related to that. I will see tomorrow after the rebalance and remount today. Thanks again.
2007 Black Camry CE
Old 03-05-2008, 09:05 AM   #9 (permalink)
Take it easy... :-)
Tobeit's Avatar
3 lbs should not do anything. I have my brand name tires rebalanced a few times, changed two tires which where supposed to be out of round and road balanced again etc. Most of my (real) vibration is gone. I have an interesting observation now - my car still vibrates a little at higher speed (not enough to really bother me) but only when cold. Once the car warmed up it is completely gone and rides smooths. I did no bother to ask the toyota shop as that is probably one of the things you can look forever and never really find out what the cause is...how about yours?
Old 03-05-2008, 09:21 AM   #10 (permalink)
Francois L'Ollonais
lollonais's Avatar
It could be, but as far I can remember with the stock tires I would be driving and not realize I was hitting 80mph. With these I can tell when I am hitting 65 without looking a the speedo. At about 80, the vibration is almost not noticible. But at 75, you can really tell. I will swap the front with the new rear one and see what happens today during lunch on the hwy. Thanks.
2007 Black Camry CE
Old 03-05-2008, 02:24 PM   #11 (permalink)
2008 SE V6
thoots's Avatar
View thoots's Photo Gallery
Well, tires (some far more so than others) are known to develop "flat spots" after sitting around, like overnight. That could be your problem. Whatever tires you've got, do some 'net searching to see if yours are more prone to that than others....
thoots
thoots is offline   Reply With Quote
Old 03-05-2008, 02:26 PM   #12 (permalink)
Take it easy... :-)
Tobeit's Avatar
Yeah, good point, that could be. My car is more sitting in the garage than most others. These are my winter tires....soft compound material. But not really an issue for me right now. Thx
Old 03-05-2008, 02:43 PM   #13 (permalink)
Francois L'Ollonais
lollonais's Avatar
Thanks for the info. I drive this car everyday now and my truck is parked. So I doubt that it could be that. The camry is parked for no more than 8 hours a day. I did the net research and could not find anything bad.
2007 Black Camry CE
Old 03-05-2008, 02:44 PM   #14 (permalink)
Francois L'Ollonais
lollonais's Avatar
Oops, found this http://www.1010tires.com/newforum/de...px?f=44&m=3557
2007 Black Camry CE
Old 03-05-2008, 03:21 PM   #15 (permalink)
2008 Camry Hybrid
Yazovets's Avatar
Gameroom cash: $149932
View Yazovets's Photo Gallery
I do not intend to sound rude at all, but what you're experiencing has a higher probability of happening when you buy cheap 2nd-rate or 3rd-rate tires.
Granted...Nexen is a name I've heard, but it's certainly a questionable brand.
2008 Camry Hybrid | Magnetic Grey on Grey Leather | Bi-Xenon H1 4300K Retrofit | Italian Hertz Sound System (dash 4" EM 100, front 6.5" ECX 165, rear 6" x 9" ECX 690, 10" ES 250D sub in custom trunk enclosure, HDP5 5-channel amp, 1320W total power) | 4-sensor Rear Parking System | 20% Metallic Tint | Weathertech Floorliners | 17" ASA AR1 Rims | Toyo Garit KX (winter) | Toyo Versado LX II (summer)
Yazovets is offline   Reply With Quote
