2002 Camry 4Cyl noise from AC bearing - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-27-2008, 10:01 PM   #1 (permalink)
View toyo9494's Photo Gallery
Anyone experience noise from AC bearing, noise sounds like coming from exhaust, but had it checked out, mechanic used something like a doctor use, and check numerous places, and told me that it came from the AC bearing, only hear noise when in gear and when initial starting, disappear when car accelarate a bit, won't hear in neutral. Any advice. thanks, I was also told not to worry about it, AC works fine, noise just come when starting slowly, even hears it in reverse. ( exhaust is in perfect condition )
toyo9494 is offline   Reply With Quote
Old 02-27-2008, 10:15 PM   #2 (permalink)
The Connoisseur
CharmCityES's Avatar
there is actually a TSB out for the early (2002-2003) model gen 5 camrys for an upgraded a/c system to improve its performance...maybe that will cover the issue?
this has been applied to my 2003 before i bought it as certified pre owned back in feb 07, and my a/c worked flawlessly all summer long with no noise whatsoever.
The "Executive Sedan"
Old 02-27-2008, 10:23 PM   #3 (permalink)
The Connoisseur
here is said TSB...
it mentions something about a metallic noise, which comes from the compressor...this might be your issue
hope this helps
AC001-03
Title:
A/C PERFORMANCE & DURABILITY
IMPROVEMENT
Models:
’02 – ’03 Camry
Technical Service
BULLETIN
April 15, 2003
TSB UPDATE NOTICE:
This TSB updates EL004–03. TSB EL004–03 is now obsolete and should be discarded.
Some 2002 – 2003 model year Camry owners may experience a condition where the
blower volume gradually decreases after about 1-1/2 hours of driving. It has been
determined that, in hot high humidity conditions, the A/C system evaporator is freezing
over, blocking the airflow path. There may be some instances where this condition may
affect the A/C compressor and clutch assembly. An in–line thermistor resistor harness is
now available to correct this concern.
2002 – 2003 model year Camry vehicles produced before the VINs shown below.
PLANT STARTING VIN
TMC JTDBE3#K#30187351
JTDBF3#K#30118354
TMMK
4T1BF3#K#3U040018
4T1BF3#K#3U547049
4T1BE3#K#3U146151
4T1BE3#K#3U668355
OP CODE DESCRIPTION TIME OFP T1 T2
AC2004 A/C Wire Installation 0.5
88501 07020
87 99
AC2005 Compressor With Magnetic Clutch 1.8
88501–95 99
Applicable Warranty*:
This repair is covered under the Toyota Comprehensive Warranty. This warranty is in
effect for 36 months or 36,000 miles, whichever occurs first, from the vehicle’s
in-service date.
* Warranty application is limited to correction of a problem based upon a customer’s specific complaint.
HEATING & AIR CONDITIONING
Introduction
Applicable
Vehicles
Production
Change
Information
Warranty
Information
A/C PERFORMANCE & DURABILITY IMPROVEMENT
– AC001-03 April 15, 2003
Page 2 of 3
PREVIOUS
PART NUMBER
CURRENT PART
NUMBER
PART NAME ENGINE MODEL QTY
88648–33120*
1 Air Conditioner Wire – 1
88320–33160 TMC V6
88320–48080
Compressor Assembly
TMC L4
1
88320–07090
TMMK V6
N/A 88320–06080 TMMK L4
88410–33120 TMC V6
88410–42040
Magnetic Clutch
TMC L4
1
88410–33120
TMMK V6
88410–42040 TMMK L4
1 Air Conditioner Wire 88648–33120 includes a wire with register, a silencer sheet and a clamp band.
1. Compressor and Magnetic Clutch On–Vehicle Inspection.
A. Start the engine.
B. Inspect the compressor for a metallic rattle sound.
a. Check if there is a metallic rattle sound from the compressor when the A/C
switch is on.
b. If a metallic rattle sound is heard, replace the compressor assembly.
Please follow the instructions in the repair manual for compressor removal
and replacement:
V6 engine: page 55–50
L4 engine: page 55–57
C. Inspect magnetic clutch condition.
a. Check the magnetic clutch for signs of overheating.
b. If there are signs of overheating, replace the magnetic clutch.
2. Install Air Conditioner Wire.
A. Remove instrument panel under
cover sub–assembly No. 1, glove
compartment door pad,
instrument panel sub–assembly
lower and heater to foot duct
No. 1.
B. Remove the cooler thermistor
connector from the blower unit.
NOTE:
The cooler thermistor connector is
clipped into the hole on the blower
unit.
Parts
Information
Repair
Procedure
Page 3 of 3
C. Disconnect the connectors and
install the air conditioner wire.
D. Wrap the connector with the
silencer sheet.
E. Install the air conditioner wire
clamp into the hole on the blower
unit.
F. Tie the connector onto the body
wire harness with clamp band.
G. Install the heater to foot duct
No. 1, instrument panel
sub–assembly lower, glove
compartment door pad, and
instrument panel under cover
sub–assembly No. 1.
Repair
Procedure
(Continued)
Silencer Sheet
Old 02-27-2008, 11:03 PM   #4 (permalink)
Thanks for your input, my situation is this, I never have any problem with the AC since purchased new ( AC works fine, never failed once ), the only thing is this noise ( happened about two years ago ) only when I started to accelerate the car, ( noise is like those people put in low noise muffler ) but only for a very short time, once the car pick up some speed, and the noise is gone. especially very loud when in indoor garage and doing parking, ( cause I will be driving in very slow speed ).
Old 02-28-2008, 10:12 AM   #5 (permalink)
480 HP 2.4L = lying ricer
TRD VVTi's Avatar
View TRD VVTi's Photo Gallery
If it really is the compressor, you should replace it before it fails completely and scatters debris throughout your entire A/C system causing damage do other componants. Getting all the debris out of an A/C system can be difficult and lead to other failures down the road.
Waiting will only cost you more.
2006 Camry LE Special Edition
