66 bore centre on a 2007 camry? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-29-2008, 03:29 PM   #1 (permalink)
camrydanny's Avatar
View camrydanny's Photo Gallery
hi
im looking at rims off a infiniti g35 sedan, 5 x114.3 45 offset, 215/55/17
17 x 7.5
but the bore centre is 66, not 60 for a camry, would i run into any problems?
would i need hub rings?
thanks
dan
camrydanny is offline   Reply With Quote
Old 02-29-2008, 03:36 PM   #2 (permalink)
Crash Test Dummy
View white07cam's Photo Gallery
yes hub rings, get those youll be set.. im not sure where to get an infiniti to toyota hub ring though
2007 Super White CE 5-spd. Stock 4 Lyfe, well I have new driver side doors and side pillar.. are those mods?
As of March 1, another $2200 body shop bill due to deer attack..
white07cam is offline   Reply With Quote
Old 02-29-2008, 03:52 PM   #3 (permalink)
'07 XLE
Gameroom cash: $283530
View njerald's Photo Gallery
Gen6
http://www.1010tires.com/hubrings.asp
or EBAY
Old 02-29-2008, 05:07 PM   #4 (permalink)
Crash Test Dummy
so helpful.. thanks
Old 02-29-2008, 06:24 PM   #5 (permalink)
FlopShot's Avatar
View FlopShot's Photo Gallery
Just to clarify, the hub rings are not required at all for you to use these wheels. Because the Infinity center bore is larger (66mm), the Camry hub (60.1mm) will fit into the hole with no problem. But that means that the wheels will be lugcentric on your Camry, no different than 99.9% of the aftermarket wheels out there. But adding the rings will make the wheels hubcentric, which would help eliminate any unwanted vibration, etc. Most people don't have a problem running on lugcentric wheels. YMMV.
2007 CAMRHEE Hybrid - SOLD! Nov 2008
Completed Mods: RK Sport body kit, 18" LexusGS430 wheels, TRD/SE springs, Rear Lip Spoiler, Sliding Armrest, Smoked Tails, Terk XM-Direct, Rear Bumper Applique, Front License Bracket, K&N, Lower Grill Chrome Accents
FlopShot is offline   Reply With Quote
Old 02-29-2008, 07:08 PM   #6 (permalink)
camrydanny's Avatar
hi
thank you
there are several rims i like, they would be lugcentric, if i get vibrations, ill get hub rings
but im still looking!
thanks
dan
