TPMS Tire Pressure Monitoring System - Is this necessary - Page 3 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-16-2008, 03:08 PM   #31 (permalink)
kalohe boy's Avatar
View kalohe boy's Photo Gallery
can I add a question to what wetherburner asked, I too wouldn't want to spend extra money for an extra set of TPMS's, but if you were able to get ahold of another set of 4 TPMS's would the dealer be able to program all 8 sensors to the computer so it will be able to read them???
IF that is POSSIBLE then it might be beneficial to get the other 4 sensors so that you can switch between 2 sets of rims with no light???
2008 SE-V6 loaded
kalohe boy is offline   Reply With Quote
Old 03-16-2008, 08:35 PM   #32 (permalink)
geoff5093's Avatar
View geoff5093's Photo Gallery
AFAIK only 5 sensors can be programmed into the TPM ECU.
geoff5093 is offline   Reply With Quote
Old 03-16-2008, 08:59 PM   #33 (permalink)
Crash Test Dummy
View white07cam's Photo Gallery
does the light really bother people that much? get a tire pressure gauge, it costs a dollar
2007 Super White CE 5-spd. Stock 4 Lyfe, well I have new driver side doors and side pillar.. are those mods?
As of March 1, another $2200 body shop bill due to deer attack..
white07cam is offline   Reply With Quote
Old 04-03-2008, 05:24 PM   #34 (permalink)
tug_slug's Avatar
View tug_slug's Photo Gallery
Originally Posted by mybuddytmil View Post
The solution is to go to a tire shop and have them to break the bead on your spare and place the sensors inside the spare and air it up, and put it back in car. Problem solved. Now you can use any valve you want and no light on dash
Are you saying that if you put all 4 sensors in the spare the idiot light on the dash WONT come on? That sounds way to easy.
2008 Tacoma 4x4 SR5 access cab
tug_slug is offline   Reply With Quote
Old 04-03-2008, 05:37 PM   #35 (permalink)
boo.hoo.hoo.
desentrix's Avatar
iTrader Score: 6 reviews
View desentrix's Photo Gallery
An easier way was mentioned earlier. Place black tape over the light.
2007 Magnetic Gray Camry LE V6:
Lit door sills, F/R cathode, trunk cathode, K&N SRI, IS250 chromes, LED tails/ bulb swaps, Katzkin leather
desentrix is offline   Reply With Quote
Old 04-03-2008, 05:38 PM   #36 (permalink)
Go camry goooooo
DrewsCam's Avatar
Gameroom cash: $184780
View DrewsCam's Photo Gallery
i had my rims on for 2 weeks now and it only goes on once and while. its not really a big deal and it resets everynight with the tires in the garage
11/19/2007 Gen 6 08 Camry SE.
Rockland Toyota / Scion Showdown 4.0 Sept 26th
DrewsCam is offline   Reply With Quote
Old 04-03-2008, 05:42 PM   #37 (permalink)
tug_slug's Avatar
I might just do that
I dont have an extra set of tires.
I finally found some rims for my truck that I like and fit over the brake calipers. When they went to put the valve stems on the rims they wouldnt fit because of the flippin TPS.
Old 05-12-2008, 02:28 PM   #38 (permalink)
Camry Hybrid User
View majesticj's Photo Gallery
I followed this suggestion and my tire dealer only charged me $6 per wheel to move the sensors. Thanks for the suggestion!
Total cost: $24
majesticj is offline   Reply With Quote
