1st mod for my 08 LE V6 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-08-2008, 03:10 PM   #1 (permalink)
2010 Camry SE V6
BlackCamSe's Avatar
Gameroom cash: $400224
View BlackCamSe's Photo Gallery
Gen6 1st mod for my 08 LE V6
Just ordered a k&n drop in air filter. Cant wait to put it in. Then I'm going to bypass the secondary intake so that valve is always opened, and do as another member(netforcer i bealive) has and remove the bottom resonator, and plug off the hole for the second one. this should by definition, give me a CIA because of the possession of the intake opening. basically all i need to do is take the vacuum line coming from the T-joint, and put it right into the valve. And netforcer, if that was you, didnt u also remove the sound dedener? where is that located?
Thanks netforcer for the awsome sig! You da man!
Seatbelt! you're piloting a vehicle were dual vvt-i hitts harder then VTEC and the torquesteer can possibly snap your wrists
BlackCamSe is online now   Reply With Quote
