2003 Camry Radiator help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-08-2008, 06:31 PM   #1 (permalink)
LoudCamry's Avatar
Gameroom cash: $181827
View LoudCamry's Photo Gallery
While jacking up my car to install new wheel, the jack slip and damage the radiator, my girlfriend forgot to pull the e-brake all the way up and the car slide and hit my other camry.
It is leaking and i would like some help into what type of glue/ patch to fix it, or i should just buy a new one.
LoudCamry is online now   Reply With Quote
Old 03-08-2008, 06:56 PM   #2 (permalink)
View Romie's Photo Gallery
If it's just a small crack, you MIGHT be able to have it patched, but I'd buy a new one. The radiator gets really hot, and there's not a lot of materials that'll hold a leak in a long time.
2007 Camry, Titanium, Completely Stock.... but not for long
Romie is offline   Reply With Quote
Old 03-09-2008, 01:44 PM   #3 (permalink)
2010 Camry SE V6
BlackCamSe's Avatar
Gameroom cash: $400224
View BlackCamSe's Photo Gallery
Gen6
Women are fucking retarted and dont belong working on cars! You could get it patched, but in the longrun youd be better off with a new one.
Thanks netforcer for the awsome sig! You da man!
Seatbelt! you're piloting a vehicle were dual vvt-i hitts harder then VTEC and the torquesteer can possibly snap your wrists
BlackCamSe is online now   Reply With Quote
Old 03-09-2008, 02:27 PM   #4 (permalink)
480 HP 2.4L = lying ricer
TRD VVTi's Avatar
View TRD VVTi's Photo Gallery
What's damaged on the radiator? A tube? A tank? You need to provide more accurate information if you want an accurate answer.
2006 Camry LE Special Edition
Old 03-09-2008, 08:57 PM   #5 (permalink)
LoudCamry's Avatar
here are a few picture, it look like a couple of hair line crack
Old 03-10-2008, 03:24 AM   #6 (permalink)
LoudCamry's Avatar
will this product work good???
http://jbweld.net/products/permoseal.php
any advise on type of patch is out there??
Old 03-10-2008, 11:24 AM   #7 (permalink)
TRD VVTi's Avatar
The tank is damaged. Either have a radiator shop replace the tank or get a new radiator.
An epoxy won't work very well, especially long term.
Fix it right the first time. You don't want to be driving and overheat the engine causing engine damage over a simple radiator.
Old 03-10-2008, 01:53 PM   #8 (permalink)
Maven
gdanaher's Avatar
Gameroom cash: $318510
View gdanaher's Photo Gallery
I agree. Replace the radiator. They aren't cheap, but next time you will check to see if the brake is set before you attempt to jack the car. I'm not even going to ask why you were jacking the car at the radiator. Maybe next time you will look at the manual before you do something else boneheaded.
gdanaher is offline   Reply With Quote
Old 03-10-2008, 03:07 PM   #9 (permalink)
LoudCamry's Avatar
well, i might just grab a radiator from toyota, it about 75 dollar more then from a aftermarket oem radiator, well i didnt jack the car up at the radiator, i jack it on the metal frame thingy where i was suppose to but the jack slip and hit the radiator part, i have jack my car up many time and this is the first/.
